Help motorhome won't start. (1 Viewer)
Dougie
16
York
C class
Since 2008
went to start my motorhome last week, it was a freezing cold morning. The van turned over but would not start. Called breakdown they spent 2 hours to no avail. Had van recovered to a garage specialist in commercial viecles. They have tried everything no problem fuel injectors etc. Nothing showing on diagnostic. Checked all compression all sensors still nothing. Any suggestions it's a autotrail tracker 2015 on a fiat. Help please.
Paul an Jane MK
435
486
Milton Keynes
Elddis Encore 255
enjoyed the freedom over the last couple of years but still Wish we could have got away more often
Immobiliser?
Friend runs a motorbike shop, majority of his breakdowns are immobiliser related.
Feb 15, 2014
713
1,249
cambridgeshire
Bessacar E450
3 years
can you try a different key could be something to do with immobiliser, would try a crank sensor as well
Dougie
Dougie
16
York
C class
Since 2008
Yes tried different key, and tried crank sensor.
Dougie
Dougie
16
York
C class
Since 2008
Yes they have checked pump, and made sure injectors opening. We have not had a second of problem, up to that morning.
When I went to start the van a warning saying check diesel filter came up. They say they have checked all this and made sure no air in system or water.
Silver-Fox
9,264
29,057
Cheltenham Spa
Rapido
im a not so newbie
When you say checked pump, is that in checking fuel is being pushed to the injectors?
If you have compression in the cylinders and fuel being injected in along with engine turning over she should run.
Dougie
Dougie
16
York
C class
Since 2008
That's what they said. The garage is very respected do work on council vehicles.
It's a strange one.
androidGB
363
490
Bristol
Since 2001
Don't wish to appear rude, but it might be better to take it to a different garage.
They have the vehicle, and I would hope would be in a better position to diagnose the problem, from us lot at a distance.
Andrew
Silver-Fox
9,264
29,057
Cheltenham Spa
Rapido
im a not so newbie
The thing is you can check the pump is pressurising but if you have a blockage in the positive line then she won't start.
Dougie
Dougie
16
York
C class
Since 2008
Yes I am beginning to think this. Just thought somebody may have had a similar problem.
Feb 15, 2014
713
1,249
cambridgeshire
Bessacar E450
3 years
there scanner should show pressure in fuel rail, there should be a relief valve which might stay open if it has overpressurised and stop rail from pressurising
Dougie
Dougie
16
York
C class
Since 2008
Thanks for all your info. You would think they have checked all these things. They say thay will look at ecu on Monday, and make sure timing belt has not slipped. Thanks everyone
Dec 12, 2010
5,408
21,553
Cumbria
since 2011
I'm sure somebody just posted about this pressure switch fault on here quite recently, seemed like a quick and relatively cheap fix. Maybe just ask the garage if they've checked it ?
Dougie
Dougie
16
York
C class
Since 2008
I will check this with them in the morning. Put this on a fiat forum and somebody also suggested this. Thank you.
soreeyes
351
136
Sunlight T69L 2017
im a newbie
Is it still under warranty ? If so as said I would let Fiat recover the vehicle .
I have had problems on new vehicles with strange results which was a hair line like crack in a filter body .
Dougie
Dougie
16
York
C class
Since 2008
Don't think they have changed the fuel filter, maybe just worth a try. Seems most people think it's a fuel problem.
