No if it's a blue butane you will have low pressure problem in the winter months.
Actually isn't butane a red bottle?
Yellow =methane !Oops - sorry got it wrong. Mine are yellow............!
Will my brother be acceptable?Still holding back on putting blower on until I get to Chester .... so that I have people around me who can tell me where I am going wrong.
This is not normal. When charging a lead-acid battery, the charge current changes the chemistry of the plates. After this is done, and the battery is fully charged, any further charge current will split the acid into gases, which is what the bubbles are.The acid bubbles off as the batteries are charged.
That was only after 1.5 years old.
Or in my case (when the alternator died) the AA man. Yippee for breakdown cover!It can all be quite frightening and a steep learning curve, heaven help an impractical newby!
Hi Joy, I rarely put my five pennyworth in these days because whatever I say someone always seems to be waiting in the wings to shoot me down in flames or criticise my advise/remarks, the lpg you are using would be PROPANE if acquired in UK as all UK lpg IS propane abroad it is a mixture of butane/propane. As has been previously mentioned if your refillable bottle is low then it will not "gas off", also whilst a lot of well-meaning funsters have suggested your leisure batteries seem to have given up, I have never had a leisure or engine battery give up after just 3 years ,but again that is down to how you look after and use/maintain them and also if you "understand" them. Remote diagnosis is always hit and miss so without being "on site" to do various checks etc, it can be difficult if not impossible to give an accurate diagnosis. the "clicking" you can hear from the heater is possibly the heater trying to ignite which is using your battery power, BUT whilst it is not igniting the burner because of the aforementioned low gas problem, the fan is running whilst it is waiting for the burner to try and ignite, thereby pulling your battery power to a point where your batteries are "cutting out" your 12v supply. I hope all this is not to confusing as I am only trying to illustrate your problem in the simplest of terms, I don't think it's a serious or necessarily an expensive problem, but I am intending to be at Chester food festival and will explain things more simply to you. Hope this helps, keep warm , will look for you in Chester.I don't know .. I just call it lpg.
You are showing off cos you know more than me.
