Minxy
- Aug 22, 2007
- 33,946
- 71,411
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
We have what we believe is an issue with our fridge ... we seem to be 'cursed' with issues with the blooming things.
Its a Dometic RML 9335 (3-way) and we found when we were away over winter that if we didn't give the centre left of the door where the handle is a good push when closing it, it didn't fully locate the locking mechanism so would open when going round corners etc. The door has a bow in it - touching at the top, wider at the bottom and even wider in the centre, a bit like a 'banana'. I've been onto the dealer to get it changes under warranty but they've checked with Dometic who said:
I need to get back to the dealer in the next day or two so I'm gonna re-check the seal etc tomorrow and would appreciate if others with similar Dometic fridge freezers could check if their doors are like this as I don't believe we should have to forcefully push the door to ensure it locks.
Below is a picture of the door which I've turned 90 degrees as it makes it easier to look at (the top is on the left).
The RML9xxx doors do have a bow to them. You’ll usually see that the top and bottom are the same and the middle is little wider.
As long as the seal is touching the body all the way around then the door is fine. The bow doesn’t affect the performance of the unit.
