Help in Turkey
Mr Ed
Norfolk.
Autotrail cheyenne
2008-20??
Like a fool I didn't check before I left UK and I find myself without the correct gas adapters to fill up.
Any ideas you guys.We have tried quite few lpg stations which are abundant but they can't help.
Martin
What are you trying to do? Fill a refillable bottle so need an adaptor for that from an lpg pump or an adaptor for a Turkish bottle to connect to your system.?
I am trying to fill my refillable system (Gas-it)
I suppose you've tried the outlet selling the LPG....🤔😀
You may need to think about disconnecting your fill pipe at the cylinder and adding a separate pipe with a Turkish filler head on the end just to fill up. Then swap back to your normal fill pipe.
Will cost but may be your only option.
This is what we did in France a few years ago when we only had calor and ran out, bought a complete french bottle and regulater and just swapped the pigtail over.
Kept us going and used on the BBQ when we got home.
In fact we still have it and everytime we go we say shall we take it back and swap it but not much point now we have gasit.
From what I've seen it appears to be the dish adaptor same as France, autogas seems to be popular in Turkey, 🙂 have you asked where it's sold ? garages normally have them behind the counter in most countries. 😁 Bob.
Sounds like a good idea,thanks
We have asked all of them that we have tried, I thought I had the french connection but having tried it in France earlier this year I found it was too small.The French usually have a supply of connecters so I have become a bit. complacent about it.My mistake but I am human.
Martin
Mr Ed .
Where are you? It's the dish adaptor you need. We are in Manavgat and have one if you are anywhere near us.
When we had the same problem in Portugal we found an LPG installer who was able to supply the adaptor we needed there!
Mr Ed .
Hi guys, we are way behind you and have just got past Izmir, its hot isn't it.I'm sure we will find a solution thanks for the offer.I have only found 3 lpg installers and they are all miles from here.We have a pipe that we use in Morocco to connect local tanks to our gasit system perhaps we can use that somehow.
Safe travels
