Help Fiat Euro,4 Injection system failure in Spain (1 Viewer)
rrusty
258
212
Scotland
None sold sept 2019
Hi,
I filled up with fuel today and the Generic failure light came on (engine oil pressure sensor or inertial fuel cut off switch triggered) after about 10 miles I turned of the engine and restart and it disappeared.
But after about another 30 miles the injection system failure light came on and is staying on after turning the engine on and off, could it be dirty fuel? Read somewhere if the battery is disconnected it will reset if that is the problem.
Fiat 3L euro 4 2010
Graeme
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Hi Graeme
You make it sound like the light came on straight after filling with fuel, if it was literally straight out of the fuel station I don't think that would not be enough distance for dirty fuel to get into the filter or is there a pickup and sensor in the tank.
Martin
Jun 10, 2010
8,421
20,056
Shrewsbury (sometimes)
N&B Clou Liner MAN
Is the title of this post representative?
It could be one of a number of things, prob time to head for the nearest garage and get it plugged in to the diagnostic machine.
R
rrusty
258
212
Scotland
None sold sept 2019
Hi Graeme
Martin
Hi Martin
Yes I know what you mean, I had done about 250 miles and it was going great prior to the fuel stop. don't know about the pick up and sensor.
Jun 10, 2010
8,421
20,056
N&B Clou Liner MAN
Your title says that the injection system has failed.
This conclusion seems premature. Imho
R
rrusty
258
212
Scotland
None sold sept 2019
That is what the symbol on the dash refers to in the Fiat manual, so if anyone else experienced the same problem and there is quite a few after doing a google search using ISF reference. That is why I used it!! What else could I call it "yellow whats it on the dash" would that suit you?
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
OK silly question time, you did put diesel in didn't you? take the cap off and have a sniff, there has just been an issue with ASDA in the UK putting diesel in the petrol pump or vice versa.
Martin
R
rrusty
258
212
Scotland
None sold sept 2019
Yes it was diesel I drove a further 80 miles on less power, it seemed and this morning started it up and everything was back to normal and done 350miles with another fuel stop.
Graeme
funflair
19,199
29,888
Guisborough
MORELO palace
since 2012
Graeme
Gremlins, they get everywhere. Pleased that it seems to have sorted itself though.
Martin
Dec 12, 2010
5,368
21,198
Cumbria
since 2011
It's not the "short lead syndrome" that's been reported on here a few times that's causing the problem is it ? Apparently the injector cabling is too short and it rubs through or disconnects a plug slightly, got to be worth a quick look under the bonnet to check ?
