Help ...Alarm Bleeping sound (1 Viewer)
S
Swanny
Hi, We are new to motorhome, and we have used the motorhome four times, we have a Autotrail Cheyenne on a Mercedes, 2004. The alarm is a Toad Alarm 850T, each time at midnight, the unit seems to set itself, and the alarm startes bleeping, not an audible alarm, but just a series of beeps, so doesn't waken the campsite, but wakens us. I have spoken to Taod Alarms, and they say there are no timing devices on the alarm so they think it is something to do with the Mercedes ECU.
Has anyone got any suggestions on what to do.
S
sinbad1
Check the control pannel think there is an option to set alarm
derekfaeberwick
1,035
9
Berwick
Low Profile
9 Years
Don't get any beeps from my Merc. Doesn't sound a very convincing reply to me. :whatthe:
S
sinbad1
perhaps i didn't make it clear ;but if you had an autotrail you would understand
quote from the tech data of the EC200 control unit fitted to autotrail
Sargent Electrical Services Ltd. Copyright 2002
Issue (draft 6) Page 8 of 10 21 October 2002​
Water Tank Fill?
<Start 1 Min>​
Allows operation of the External pump for a
period of one minute (for filling the internal
tank from the external tank)
Use the select button () to START (or
STOP)
Will have no effect if the
External pump is already
switched on (see above)
Will not operate if the Internal
(Fresh) water tank is showing
100% Full​
Clock Set?
12:00​
Access to set the internal clock
Press the select button () to select HOUR
Use the up / down () buttons to change
Press the select button () to select MINUTE
Press the select button () to exit
Please note the clock uses a
24 hour cycle​
Alarm Set?
12:00
Access to set the alarm clock
Please note the alarm uses a
24 hour cycle
Alarm = Off ::bigsmile:
Regards
43,299
49,286
Alarm Set?
12:00
24 hour cycle
Regards
do you mean you've fixed the problem?
if not it appears to be exactly what it says on the box.....an ALARM CLOCK...ie-- wakey wakey, get up you lazy ba**ard!
nothing to do with the toad intruder alarm.
if you cant turn it off just set it for a daytime alarm time when it wont bother you...::bigsmile:
S
Swanny
Hi All,
Just like to say thankyou for all your help, we think we may have fixed the problem, trying the motorhome this weekend, so we will soon know.
Thanks again
Diane
