Heki roof light shock (1 Viewer)
Dec 23, 2015
444
522
Audenshaw
Pilote Pacific P650GJ
Over 6000 miles between 3 March to 26 September 2017.
Just been up to check Lottie in storage after the bad weather. On the surface everything looked fine, I looked up to open the blind on the Heki roof light and it was all "pushed down" and had come out of the runners at the side. I feared the worst, that maybe the roof light had somehow smashed and the blind was full of either snow or water. It felt dry on the inside and I tentatively pushed up on it, there was no resistance. It was only at this point that I noticed it had come out of the runners so I carefully pushed it back in at each side. Thankfully the creased pleats went back into place, apart from a couple which I just pushed up. On opening the blind we could see no reason for this happening, the roof light was intact and firmly closed. I can only imagine it was something to do with the pressure of the snow on the outside. Has anyone else ever experienced this. The other two smaller roof lights over the bedroom and shower room were fine.
DuxDeluxe
14,657
72,615
Planet Zog
A woosh bang van
since 2008
It could have been wind pressure in the recent high winds. They recommend that you don't drive with the roof blinds closed for this reason (I had endless fun getting the pleated bit back into place) and the effect of high winds could have been similar. Just a thought.
No doubt someone will be along shortly to tell me that I'm wrong....
Jun 30, 2011
7,229
20,074
Barnard Castle, UK
Concorde Concerto
I must say I never heard that one before''Don't drive with roof blinds closed''. Never had a problem in all the years.
DuxDeluxe
14,657
72,615
Planet Zog
A woosh bang van
since 2008
I found the problem with my auto sleeper - it was in the paperwork somewhere but I cannot remember where I read it. After two incidents where the blind had blown out of the channel, I decided just to open the blind by about an inch or so and never had the issue again, so always do it now, if coming out of storage where it lives with the blinds shut. Only happened with the big one
Jul 5, 2013
11,722
13,698
Since 2013
At the handover of both my mohos from different dealers I was told never to drive with the blinds shut.
Some rooflights are deliberately not sealed when they are fully shut, so as to allow for ventilation. If that is the case with yours then wind pressure as suggested by @DuxDeluxe is the likely culprit.
ambulancekidd
Sep 23, 2014
10,354
28,382
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
We were staying on a CL mid winter & during a storm the bling on our Heki roof did exactly the same thing. Pushed it back into shape & into the runners with no ill effects.
Aug 27, 2014
1,910
3,886
Shropshire
McLouis Tandy 640+
Since 2014
Agree, wind pressure - mine has done it when parked up on a particularly stormy day. The rooflights aren't perfectly sealed to allow for a little "trickle" ventilation, as others have said.
Diggerdi
Dec 23, 2015
444
522
Audenshaw
That must be what it was then, we have had some extremely high winds over the last few days. We never drive with any of the blinds closed, but always close them all at the storage yard. It seems silly closing the roof blinds, but we have a cctv camera directly above our moho and once I forgot when I used the loo whilst there :oops:
icantremember
8,328
17,540
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I believe also you shouldn't keep blinds fully closed in direct sunlight as the heat buildup can damage the rooflight.
Diggerdi
Dec 23, 2015
444
522
Audenshaw
Don't think we've had any hot sunshine since we got it 12 months ago!
scotjimland
2,256
9,780
A Woosh bang
Heki can be supplied with or without forced ventilation.
if forced ventilation, air pressure can push the blind down ..
The Nomad
1,052
1,064
Wandering in Europe
Overcab
Many years
Gusts of very high wind does it.
Our solutuon is to leave the blind a few inches open, to allow air forced into the roof light by big gusts of wind to pass the blind.
skylinersi
1,186
952
midlands
Van conversion
newbie
winds, and heat i have found do it on ours!!, they just push back up, worrying first time it happens tho!
Northernraider
27,384
176,962
On the sofa ....
Mobilvetta eurayacht
On and off since 95
There's a sticker on my large rooflight that says not to leave closed during the day or for long periods.
I never use them anyway no one can see in them
skylinersi
1,186
952
midlands
Van conversion
newbie
good point, our dealer said not too completely shut the blinds (only 75% or so cloesed) if hot as that would happen, amazing what you forget so soon lol........
Blue Knight
5,232
5,704
Durham
Globecar Summit 640
You must have a different setup to us Dianne as ours are all fully sealed.
