- Apr 30, 2018
- 1,985
- 4,400
- Adria Matrix 670DC
- Motorhoming since 2018.
The net screen on the heki roof light has broken. I've just been on you tube, apparently its a fairly common fault. one of the plastic lugs that guide the tension string has broken off. I have managed to super glue the lug back on. the problem is I need to remove the inner section of the roof light to put the tension strings back on.
I think I can gleam enough details from you tube to fix the problem, however the problem I have is; how do I remove the decorative panel which sits around the heki roof light to enable me to remove the inner plastic surround for heki roof light.
The first picture shows the plastic lug which I stuck back on
The other 2 images show the decorative panel which I need to remove.
Thanking you in advance.
