Heating System
Discussion in 'Chausson' started by Bepto, Oct 25, 2017.
  1. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    My 2016 Flash 737 has a truma heating system but the control panel has the following options for heat source FUEL, Mix 1, M ix 2, Elec 1 & Elec 2.
    I thought most truma systems had GAS as the 1st option. Does this mean that the heater uses the Vehicle fuel i.e.: Diesel to heat the van?
  2. Riverbankannie
    Riverbankannie Funster
    Mar 11, 2016
    2,249
    Bristol
    Ratings:
    +3,563
    If it is a Truma combi, then probably refers to mix of electric and gas. Do you have a Truma manual?
    This is the relevant page for mine but I have the usual Truma controls
  3. CCC
    CCC Funster
    Sep 16, 2016
    663
    Spaldwick, Cambs
    Ratings:
    +2,643
  4. BobtheBass
    BobtheBass Funster
    Nov 11, 2013
    921
    Tewkesbury
    Ratings:
    +4,582
    Chaussons often use the diesel Truma system instead of gas. Very good system that doesn't let the vehicle tank run dry.
  5. rogher
    rogher Funster
    Aug 4, 2011
    1,474
    West Midlands
    Ratings:
    +1,388
    If yours is a Combi D, it uses diesel rather than gas. If unsure, you could try running it with the gas turned off. You'll soon see...
  6. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    It appears from my paperwork that the boiler is a Combo D6E which runs on Deisel or Electric or both. Shame it doesn't work at the moment.
  7. rogher
    rogher Funster
    Aug 4, 2011
    1,474
    West Midlands
    Ratings:
    +1,388
    Does it 'do' anything at all?
  8. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    Gives an Error code E122H whether on fuel or electric. Replaced the fuse in the main fusebox which looked fine & today took the 10a fuse out of the boiler itself, that looked ok too but when I went to put the fuse back I dropped it and now can't find it, its down amongst all the pipework under the bed somewhere. Anyways I have booked it into Brownhills in a couple of weeks. Boiler should be under warranty but assume there will be some charge for looking at it.
  9. rogher
    rogher Funster
    Aug 4, 2011
    1,474
    West Midlands
    Ratings:
    +1,388
    I think that may be "lack of fuel". You need at least 1/4 tankful. Maybe you're on a slope?
    Did you try whilst on EHU (before discarding the fuse)?
    If I recall, E112H is a general condition for being unable to heat. I'm sure Brownhills will sort it.
  10. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    Not on a slope but am under 1/4 tank but got the same error using it set to Elec 1 or 2 on EHU.
  11. rogher
    rogher Funster
    Aug 4, 2011
    1,474
    West Midlands
    Ratings:
    +1,388
    Let us know what Brownhills discover.
  12. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    Will Do.
  13. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    Spent 6 hours at Brownhills today, the highlight was breakfast in the bistro yummmm.
    End result was its a pcb fault & needs replacing (the PCB) they don't stock it so have had to order and issue a warranty claim to Truma. They will let me know when it arrives and I will have to book in again to have it fitted.
    Dont know how long thats going to take but at least it hasn't cost me anything other than time.
  14. rogher
    rogher Funster
    Aug 4, 2011
    1,474
    West Midlands
    Ratings:
    +1,388
    ... and chance of another breakfast!
    Hope it does the trick.
  15. Bepto
    Bepto Funster
    Jul 29, 2016
    82
    sheffield
    Ratings:
    +78
    Another 7 hour stint at Brownhills yesterday, yes you can get sick of looking at motorhomes.
    Disappointment again - they replaced the PCB and found it needed a glowplug as it is a diesel model - how that took 7 hours I don't know (was told it was 2 hours work to replace the PCB beforehand)
    I wasn't best pleased as they don't stock the part so was told they would let me know when it arrives and re-book me in. In the end I told them I would rather leave it with them until it is sorted, its no use to me in this weather with no heating. So I got the 2x trains home. Left home at 07:30 am & got back without motorhome at 18:00. At least they gave me a lift to the station.
    So now to await a phone call hopefully this side of x-mas to say its fixed, then train back there. What a polava.
  16. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,422
    Norfolk
    Ratings:
    +9,281
    Webasto send out a complete parts kit to their service centres.
    The kit is sent back after the repair and the service centre pays for the parts they have used.
    Then you do!
Similar Threads
  1. Bepto
    13
    357
