Mitzimad,The yellow lever was in upright position when this happened,I moved it horizontally later when I was trying to workout it’s use
there is nothing in the blue valve that is temperature sensing
Thank you, I hate being wrong but I'm always willing to learn.
But I'm puzzled, if it is just letting air in then in reality it does not need a pipe to the outside. The other end of the that looped pipe will be blocked by the manual dump valve. So what popped the pipe open ?
AH!! The dump valve could be open, naturally it would dump nothing but it would mean both sides of the red valve would have equal pressure on it, for what that's worth ???
This confirms "breather" not pressure relief:
https://www.caravanaccessoryshop.co...astore-elbow-push-fit-with-breather-pipe/3248
Yes - saw that & assumed the OP would fix it anyway. I was concentrating more on correcting the obvious (and weird) plumbing under the van . And I was wrong about which valve did what.A problem Tony, the pipe has burst above floor.
So yes, one half to the dump valve will be OK if cut underneath, which is good looking at all that crap slapped around the pipe as it enters the floor, but it still needs renewing to the PRV.
Edit: I think the red elbow needs a pipe to outside because it can dribble a a bit when you fill the boiler - the check valve is a loose ball, not spring loaded.
