I can't speak for the Rapido but both my Hymers used a CH system duct to the tank.Hi, I have a A class 8066DF it says it has a heated waste water tank does this have an element in the tank and if so is it automatic and how do you know if it is working, never found a switch in 4 years.
many thanks Bill
I have a 2017 8096df and I believe that the blown air heating system vents around the waste tankHi, I have a A class 8066DF it says it has a heated waste water tank does this have an element in the tank and if so is it automatic and how do you know if it is working, never found a switch in 4 years.
many thanks Bill
Hi Bill, I am pretty sure that the double floor (DF) Rapidos run the Truma heating ducts or Alde pipes through the area around the tank, like our Hymer has. That ensures that it does not freeze.Hi, I have a A class 8066DF it says it has a heated waste water tank does this have an element in the tank and if so is it automatic and how do you know if it is working, never found a switch in 4 years.
many thanks Bill
