- Jul 17, 2009
- 188
- 155
Our old 2009 Boxer MH had markings on the headlamp lenses to indicate where to place the European headlamp deflector stickers, new 2016 has no such markings, do I just guess ? or don't you bother anyway !
Thank you for proving my point !!!!!Easy peasy how too
First thing to know is we are not trying to deflect or bend anything so Beam Benders and Beam Deflectors are slight misnomers,
What we are aiming for (note the pun) is "Masking the light patterns.
Drive up to a flat surface, wall or garage door, switch on Dipped headlights and look for a pattern as in pic 1.
Its the area colour'd red we are trying to Mask out as in Pic 2.
We hope to finish up with a flat top light image as in pic 3 ie the kick up has been hidden by you tape etc
a small piece of cardboard waved in front of the lamp touching the glass itself will indicate were your gaffa tape or other masking materials should be fixed
the same rules apply if masking R/H or L/H or even obscure oddball headlamps pic 3 is the final goal of the exercise and ill borrow @Zigisla term a "Neutral" image
G
View attachment 154764 View attachment 154765 View attachment 154766
this is the easy peasy answer !!!!!Headlight protectors for the latest generation Fiat / Peugeot / Citroen X290 have clear easy markings where to mask with black tape.
We've had headlight protectors on for 10 years. EGR for particular model. Put into place and there's a square sticky black bit to put on where marked. With it not being on the headlight itself, it won't burn. Once fitted, never need (except for cleaning) to take the protectors off as it goes through our MOT without a problemHeadlight protectors for the latest generation Fiat / Peugeot / Citroen X290 have clear easy markings where to mask with black tape.
And they are MUCH easier and quicker to fit than the previous X250 models - the new ones just clip in place, just a case of lifting the bonnet lid.
You can get them from Van Comfort: http://vancomfort.co.uk/headlampdeflectorspage_000.htm
We only take them off when we're travelling in the UK during winter and more likely to be driving in the dark. Removing the protectors with the blackout tape maximises the light output.We've had headlight protectors on for 10 years. EGR for particular model. Put into place and there's a square sticky black bit to put on where marked. With it not being on the headlight itself, it won't burn. Once fitted, never need (except for cleaning) to take the protectors off as it goes through our MOT without a problem
We travel day and night in the UK and by keeping them in place doesn't affect any light. Tbf, the light deflection was a bonus as the headlight protection was more important and there is absolutely no detrimental affect to the quantity or quality of light when in UKWe only take them off when we're travelling in the UK during winter and more likely to be driving in the dark. Removing the protectors with the blackout tape maximises the light output.
And as I mentioned in the previous post, they only take moments to fit or remove on the latest model X290s.
Have you checked EGR?Never found protectors for transit cabs for some reason perhaps the units are cheaper to replace if dammaged
I'm somewhat puzzled how the quantity and quality of light can be unaffected when the light output is partially obscured by black tape?We travel day and night in the UK and by keeping them in place doesn't affect any light. Tbf, the light deflection was a bonus as the headlight protection was more important and there is absolutely no detrimental affect to the quantity or quality of light when in UK
I appreciate that, however it is to deflect the light on the continent so it's directing it's beam away from on coming traffic as ours are over here. If there was ANY detrimental affect whatsoever, it would no pass the UK MOT which it does. Passed every time for last 9 years. I'm no luminaire expert but I would have thought that if there was any lack of output by the lights then it would fail the MOT.I'm somewhat puzzled how the quantity and quality of light can be unaffected when the light output is partially obscured by black tape?
I take the view that the lights are designed in such a way as to maximise their efficiency and provide the optimum light output for UK use. Otherwise, they would be designed to the altered format suggested.I appreciate that, however it is to deflect the light on the continent so it's directing it's beam away from on coming traffic as ours are over here. If there was ANY detrimental affect whatsoever, it would no pass the UK MOT which it does. Passed every time for last 9 years. I'm no luminaire expert but I would have thought that if there was any lack of output by the lights then it would fail the MOT.
The Black square is only about 2"
Firstly you are reading more into that than I said.I take the view that the lights are designed in such a way as to maximise their efficiency and provide the optimum light output for UK use. Otherwise, they would be designed to the altered format suggested.
In the same way that I wouldn't run a vehicle with the bare minimum legal limit of tread (but which would pass an MOT); I prefer to benefit from the enhanced safety of operating the van with a greater tread depth. Thus I want my lights to work as effectively as possible, not just the minimum level to get through an MOT.
The MOT sets a minimum standard required, not necessarily the best standard available.
I think we are probably going to have to agree to disagree on this one. I don't have a problem with anybody using their van how they wish.Firstly you are reading more into that than I said.
You can take it how you like but I'm only saying the facts as the manufacturers of the headlight protectors state. They have absolutely no detrimental affect on UK roads and it does not affect the illumination for UK roads.
Best thing is, either don't use protectors or buy the little bits of black sticky plastic and remove.
It won't stop me or others using the protectors because it protects the headlight and I could remove the protectors if I wanted to but why? They are there for a reason.
If you have the proof that the small black square is detrimental then by all means say so but these companies that make them, do so with good knowledge.
I certainly wouldn't run my tyres to the bare minimum either. The company I work for changes at 3mm rather than the getting towards the minimum depth of 1mm
