Has my thermostat gone (1 Viewer)
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Driving home from Scotland temperature gauge went to hot .on stopping to check I noticed top radiator hose was Not hot.header tank still full engine did not feel red hot. No steam or anything to suggest overheating. A couple of times gauge went between full and half hot.managed to get home.Do you think it' the thermostat or radiator sensor. It needs a new timing belt this year so wondering whether to change water pump at same time.Its on a 2.8jtd 2004.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
I don't know about your thermostat but I would go for the new water pump at the same time as your new belt ,
If the water pump runs off timing belt it is better to change at same time if pump fails it can damage engine same as timing belt failure
Oct 2, 2008
4,469
7,955
Salopia
Duro 6x6 Overlander
since 1968
As prev posts if belt drives water pump change pump same time .
Check coolant level when cold , esp in header tank .
May be sensor , or check wire from sensor is not shorting to earth, as this will show top of guage reading . If all checks OK then possibility of sticky thermostat although pretty rare .
Two on Tour
10,321
50,916
Elddis Autoquest 175
Since 2010
We had this last summer. Temp gauge went up to hot hot and then down to normal then up to hot and so on. Pulled over all seemed ok under the bonnet. Was a pig to start again but got it going and we drove the next 80 miles to our destination with the windows down and the heater on and the blower going full blast just in case. Turned it off when we got there and to cut a long story short we came home on the back of a flatbed as the electrics were acting very odd.
Scratched my head and checked over the van and found there was no earth strap between the engine/gearbox to the chassis. Although it should have had one it looked like one had never been fitted. Made up a strap from 10mm2 cable, bolted it on and bingo, all working as it should do again. Never played up again.
This was on a 2004 Ducato 2.8 jtd
If you wont to check for an earth strap on your then it should run from a bolt on the gearboc to the chassis leg on the passenger side (RHD)
Masman
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
No.not pushing. Got up this morning gauge still showing red.Its booked in for cambelt. Looks like a wiring fault. They will sort it .
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
There is no need to replace the water pump with the cambelt as it is not driven by the cambelt on the 2.8 engine, obviously if there is a problem with the pump, it leaks or is creating a water flow issue then it needs replacing but there really is no need for a routine replacement with the cambelt. The 2.3 however is driven from the cambelt so it makes sense to replace the pump as a routine job with the cambelt.
D.
Masman
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
Thanks for replys. Booked in for cambelt, water pump ,The guy I use thinks it' a wiring fault or sensor. Hopefully all sorted then we can look at going to spain for a month
D.
Dave. The van is a 2004.Do you think it' worth changing the pump.we will probably touring spain for a month or more.The guy I use regular sèms to think so to be on the safe side.Had a new radiator fitted last year as it was leaking. So cooling system should all be covered then
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Unless there is a fault with the pump there is no need to change it, they generally go on for hundreds of thousands of miles, we only recommend replacing the pump when it is cambelt driven because if the pump fails it will almost certainly wreck the engine.
Your temperature gauge issue may be the instrument panel, it could be an earth fault although the engine earth strap usually causes other faults first or it could be a faulty sender.
D.
wanderer
643
769
huntingdon
a class Arto
since 2008
Also have a 2004 2.8 jtd . Had a problem with the temp guage jumping up to the red and back again , it turned out to be a faulty sensor. I have replaced 2 cambelts in 10 years and not touched the water pump.
Oct 29, 2008
5,068
5,949
West Yorkshire
PVC
since 2008
If the top of the radiator is not getting hot at all I would suspect a thermostat or air lock not a sensor.
Jan 27, 2009
872
3,359
Leyland Lancs
since 2001
D.
I thought one of the main reasons for replacing both the cambelt and water pump at the same time was to minimize possible future garage labour cost for stripdown/rebuild to replace the waterpump only?
Oct 2, 2008
4,469
7,955
Salopia
Duro 6x6 Overlander
since 1968
If the waterpump driven by cambelt , waterpump failure is same as belt failure, If not driven by cam belt then consequences not catastrophic , and also does not usually require removal of cam belt so lot less costly , they also usually last lot longer than belt change interval.
Masman
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
Van sorted. Yes it was the temperature sensor. Had thermostat changed at same time.waterpump changed while having cambelt changed as there was a bit of play in it.So, new radiator last year ,Got myself a complete new cooling system
PaulMarlin
4 years
Ooh, it looks like I'm a little late on this one.
My 2004 Ducato 2.8JTD also has the erratic temperature gauge. I've had the van for 4 years. The gauge can hit the top at 200 yards, 200 miles, anywhere in between, or never. The coolant level is ok and the engine doesn't seem hot when it's happening. I've had a few fixit episodes:
1. I found the rubber boot round the sender connection had split and was full of water, dispensed with the boot and the gauge went better for a while.
2. The crimps in the sender wiring were badly corroded, so I replaced the crimps and the gauge went better for a while.
3. I replaced the sender and the gauge went better for a while.
4. Found a suggested fix of unplugging the instruments, checking the PCB for dry joints and reseating the plugs. Unplugging the instrument cluster isn't too hard: two big TX screws at the back and two smaller ones under covers at the front of the surround. On the other hand, getting to the PCB is very fiddly, no dry joints found and the gauge went better for a while.
5. Just been through the service history (my van has been pre-owned a few times) - the sender and thermostat have both previously been replaced two or three times, so I don't like the sender or thermostat theory anymore.
6. Sometimes the gauge seems to play up more when driving in the rain - anecdotal and I haven't measured it. The terminals face the front of the vehicle and it is plausible they are getting wet, see item 1, but I can't seem to find a part number for a new boot. Anyway wet / dry behaviour may point to a bad / missing ground connection suggested by two on tour above.
7. Another suggestion is the sender wires grounding out somewhere else due to chaffing. On mine there's about 6" of free wire before it disappears into the loom, so I reckon that will be ok.
Next steps:
The van is due a cambelt and I was going to change the water pump at the same time, but if the pump isn't driven by the cambelt, as Dave Newell lvs suggests, maybe I just check / fit the engine earth strap.
