Has anyone driven off the end of their levelling ramps?
West Cumbria
Rimor Horus 40
Often wonder if this has happened (it must have) and what the consequences are, and what the recovery process is.
always ultra careful when doing this especially when doing it on my own.
Probably has, depending on which wheel set and ramp height and clearance would dictate the recovery.
We have good clearance and I would expect to just pull our milenco Quattros back out. Not that we need them on out latest van as it has E&P self levelling, saves running off the ramps lol
Did it once with a set of Fiamma ramps and the pointed end jammed hard under the van. I just jacked up each side and removed the ramps. No damage to the van fortunately, but both ramps cracked. Bought Milenco and have always been more careful especially now I don't travel with a navigator. 😢
swapped mine for the scooped levels so you can easily determine when you at the end position, providing you can count to 3 that is - Milenco.
I came off the end once and, although not 100% certain as a while later, the jolt having gone off the end may have contributed to the 5m canopy subsequently dropping straight down off the rail - Thule Omnister. The rail is firmly fixed to the motorhome and then the canopy just sits in the continuous male/female bracket by gravity - with simply 5 small self tapping screws underneath. But again not sure.
I have never driven off the end in 12 years of solo travel, I have, however, often had to get back in the van and drive it up a further notch due to being over cautious. Fiat 9 speed auto box (last 3 years) has made things so much easier than my previous(y) manuals.
Yes once or twice over the years on the Fiamma / thule Jumbos. Not sure why they call them that as they are not that big. I think it was on the back and the ramp just got wedged a bit under the van, no harm done. I bought some monster Milenco Maxi T3's this year though and they are massive. The highest blocks in the world apparently. I wouldn't want to go over the top of one of them. Bad decision though, they are awful to get up on and almost impossible to reach the top level anyway. Oh and one of them has cracked already. Sending them back.
I've have only used mine a number of times and follow similar procedure to you
I know someone on here ( no names) who did that and wiped out his mudflaps, quick squirt of WD40 and leave overnight, fitted right as rain next morning( NO it was not me!) :giggle:
Yes I have , even with my wife shouting STOP. I had to jack the van up to remove the ramps and buy my wife flowers as an apology. I’m now thinking of having TESA auto lifting fitted
Yes it has happened and it’s quite frightening. Van parked level with me but at least 8 metres away, drove off the front of his ramps. It shot across smashing through my kitchen window and damaged the side wall. I was washing up at the time and saw it spinning towards me.
