Hartal fly screen
swift voyager 475
So shut motorhome door on Hartal Flyscreen smashing bottom clip off. Ordered new one states need to release cord err no way. I cut two slits in new clip opposite side to which cord runs and threaded new clip on works like new. Bit of patience all good
Oh wow - I've done the same thing breaking the bottom clip ☹️
Can you advise where you got the replacement clip and say a bit more about how you removed the old clip?
I'll be grateful for any/all help and advice 👍
Menis
Bought clip on eBay 15.00 if your flyscreen opens from left looking from outside its left clip you require. As I had smashed mine as shown I placed new clip next to it took photos of how cord went. Cut remains of old clip of with cutters keeping away from cord. Made two junior hacksaw cuts away from where cord runs in new clip threaded cord in. One small screw locates in place. Gently put back on runner job done. You are mostly laid on motorhome floor. No way was I going to cut cord
There is a small cover on front of clip when you remove with a thin screwdriver shows the cord. Best way order new clip and take 5 mins
Thanks so much for the info - will order a replacement and the give it a go 👍
Menis
Hi Parney,
Here's my photos - are these marked where you cut yours ?
Menis
Yes as near as that my first picture shows how line runs. Mine works perfect 15 quid and a bit of messing
Here is mine good as new
So thanks to advice from parney my broken Hartal hab-door flyscreen is now fixed !
Another example of the information and support made available by members of this great website 👍
Menis
Need to do the same and bought RH and LH clips. Now I know I need LH clip. Cheers
Good luck take your time it’s a bit fiddly but way better than cutting cord. I do think it’s a poor design when you can shut door and break things. Just looking at what I can do as a reminder to myself make sure flyscreen is pushed right back.
