Habitation door not locking
Bristol
Pilote G740
Since 2019
Hi All
just been doing some odd jobs on MH and notice that the Hab door doesn’t lock when I press central locking on FOB.
Will lock with key so not the end of the world but would like to get it sorted.
Any advice greatly appreciated.
Happy New Year to all!
maybe just a clean of the contacts. happens to our van now and again. do not use any form of abrasive paper just some thing to clean the crap off the surface.
Thanks Phil excuse my ignorance but where would I find the contacts?😂
That'll be it, bit of a rub with sandpaper then a bit of vaseline and all good
It’s ok I think I know what you mean I’ll give them a clean thanks
Was / is a common problem on Autotrails fitted with the Hartel doors.
As mentioned above, the contact become corroded as the cheapskates used plain steel.
Not sure if same type fitted on yours but worth a look and clean as required :xThumb:
Mmm I thought I knew what you meant re contacts but now I’m not so sure. Think the mechanism is covered by the lining on the door (if that makes sense).
There is a locking sound coming from the door but it doesn’t actually lock?
Ah, if you can hear the actuator in the door then you must be getting power through to it.
Not completely familiar with your door, but I have read somewhere that some suffer from a part of the mechanism at the lock coming loose. But I would check the contacts first.
They can be on either side of the door and can be 2 spring loaded plungers or simple flat metal contacts or in my case both.
On the Carthago the green wire comes loose on the contact pins
Has it ever worked that you know of for sure?
Thanks for the advice I’ll check it out tomorrow👍👍
Hi All
This will be the problem on the Pilote hab door - see thread below.
All the best,
Andrew
