Habitation Door Lock issues (1 Viewer)
May 22, 2016
77
22
Surrey
Adria Matrix 600DT
Since 2012
The lock barrel on our Hymer has fragmented and stopped working. It looks like a Vecam barrel in the Hartal (?) lock. Unfortunately the key slot is actually blocked and I cant insert anything to disengage & extract the barrel. Is my only option to drill it out? How easy is this to do or should I get a locksmith on the job?
Oct 7, 2015
736
3,576
newark
Swift escape 624
Can you remove the inner door panel,if so it is just a clip that holds the barrel in ?
jumar
3,688
11,206
Spain
Hymer Tramp
Since 1994
Mine has become a problem...Hymer...like above....take out centre screw that combines the keyway, handle and inner handle...plastic thingy...the barrel can be pushed through and replaced..All done from the inside of the door panel...
