Saltings
Just thought this may be of value to other "newbies" like us!
When it comes to trying to charge the Hab. battery many builders put the battery under one of the front seats. It is a two man job to remove the seat etc.
My tip is that the next time you have to do this get a Cetek charger before removing the seat. With it you will receive two extra wires and a contact socket that connects to the charger. These wires can be bolted onto the battery terminals and the end of the wire with its protected socket can be tucked under the front seat. It is then just to connect the Cetek charger to this contact when you next need to charge the Hab. battery.
These wires can also be used to check the voltage between the terminals very accurately.
Hope it helps.
Saltings
Hope it helps.
Saltings
