Ground anchors/security eye mounts ?
Jan 11, 2018
426
161
I've just bought a really good chain lock to secure my 2 bikes to the rear mounted cycle carrier.
But I accept that it is not too hard for a scrote to cut through the carrier tubing or maybe unbolt the carrier itself (usual Fiama type)
This started me thinking about installing an eye bolt or ground anchor type fixing directly bolted through the rear part of the motorhome
The chain lock is long enough to go around this and 2 bikes (1.4m long)
Has anybody fitted one and if so which would you recommend ?
TIA
596
Presently Banned
Sep 9, 2019
1,133
1,699
RV
10yrs plus
Have you not got a tow point? if not bolt something to the chassis (y)
Minxy Girl
20,015
21,040
E Yorks
Carthago Cmpct i-138
Since 1996
Check your bikes are insured whilst attached to the vehicle as some policies insist they are secured to an immovable object.
Sep 26, 2013
2,434
1,854
Market Rasen
Self Build
Since 2003
I bolted the rack to the van door and used the fixing things that were bolted to the van floor when I bought it.
Jake Royd
Jan 11, 2018
426
161
Thinking out load really.
Not as safe as round the nudge bar but now investigating security bolts where the carrier clevis bolts are.
Sep 26, 2013
2,434
1,854
Market Rasen
Self Build
Since 2003
But could these not be simply unscrewed ?
The bolts and plates on the inside of the door are doctored a bit so they will not come off.
I fitted them mainly to hold the straps which keeps the bikes in place and also the cover.
Aug 18, 2011
7,036
7,156
derbys
AUTOSLEEPER SYMBOL
There must be a towing eye on the front of your van or an eye Bolt that screws in..BUSBY.
Jake Royd
Jan 11, 2018
426
161
Ok good idea.
Jake Royd
Jan 11, 2018
426
161
Didn't have the MH with me when I wrote earlier.
Got it now.
Fiama have rivetted the frame to the 'wall' mounts so now feeling less vulnerable.
I thought they were bolted on.
Sorry for any confusion caused.
7,744
6,076
Tunbridge Wells
Since 2013
Got it now.
If the scrotes want your bikes it will take 30 seconds with a battery powered angle grinder to cut through the bike rack and have the whole lot in the back of a transit
Aug 6, 2013
8,145
7,121
Kendal, Cumbria
since 1999
Got it now.
Those are coach bolts & there'll be nuts on the inside. Equally secure though.
Jake Royd
Jan 11, 2018
426
161
Yes I know but if I have taken reasonable precautions it displaces the crime elsewhere.
Exactly like your house.
Jake Royd
Jan 11, 2018
426
161
Thinking back maybe the ground anchor or eye is the best idea.
But which one?
Jul 5, 2013
7,744
6,076
Tunbridge Wells
Since 2013
It is up to the individual as to what is "reasonable" and that will be a balancing act between the cost of security measures and the likely cost of the loss if the worse happens. If you just have run of the mill bikes then I would agree with you that what you have done is reasonable. But some people on here often carry very expensive bikes, either because they are specialist mountain or road bikes of because they are the more expensive electric bikes. In those cases a couple of bikes may represent an outlay of £5,000 or more, which is a very tasty target for the scrotes. That is when the balance becomes more difficult, and, in those circumstances, I would not want to just rely upon the rack being bolted down.
As it happens we bought a moho with a garage so we had nothing attached to the outside of the motorhome and on display. That I suspect is the best security measure. As it happens we have a scooter in that garage, so no bikes. We bought the Vanbitz Growler alarm and non-starter which has all doors alarmed and we get a message on our phones if the alarm is set off. It also has a bike loop which you can use for bikes on the rear of the motorhome. We only use it when we leave the scooter out on an Aire or campsite.
SMC Motorhomes Newark
Johns Cross
Safeguard Motorhome Insurance
Rhino Installs
Friendly professional service from qualified technicians
Free Club Stickers
