Alko-kober is the replacement chassis therefore the Alko plate supercedes the Fiat plate.The steel plate says 3500kg, which one is right?
You need to know if you can uprate that chassis, if you can you may need air suspension and larger wheels/tyres.Could I uprate say 200kgs how would u go about it thanks
Neither, the converters plate will be the one you need to look at. The Al-Ko plate shows 3850 but the converter may have downplated to 3500. V5 should be the same as the converters plate.The steel plate says 3500kg, which one is right?
