Grey water pipe and tap
BigBee
Hampshire, UK
Swift Rio 340
Hi we recently bought a swift Rio340, our first MH, used it twice and things are breaking. The habitation door glass broke in two and I understand this is a common fault, so we will use silicone sealant and a sticker to cover it. Today, the grey water pipe and tap fell off somewhere on M25. Any idea where I can get a replacement and if this bracket is as it should be, or is also broken - it was like this when we bought her.
The bracket is as it should be, looks as though part of the grey bit has broken off. CAK tanks might have the parts you’re looking for. When I broke ours on a bush (don’t ask!) I ended up buying bits from a chandlery in Lymington.
Just taken a photo of ours for comparison.
Not sure if the photo is loading, our internet connection here is rubbish 😔
Thank you for the welcome. Not sure how to reply to people - I'm technologically inept 😉
I2C, sorry can't see a photograph, but thank you for trying 😊
I have a tap that would fit your clamp. I broke the clamp so had to buy tap as it came with the clamp. I got the whole thing frome onebuy. Same as eBay I am in Wales but heading up and down the m4 as far as Chieveley Wednesday and Thursday next week
here they are about the same price that I paid last year but do you need some pipe as well my tap does not go directly into the tank
I think my husband BigBee2 (just joined 😇) may have found one online...might need to buy a few as it looks like a vulnerable point. Many thanks for the advice
I fitted that exact same one to my grey water drain pipe last week. The two piece clamp bracket doesn't grip the tap very firmly so I've fastened a cable tie around the clamp to keep the two halves of the clamp closed tightly around the tap.
I suspect that the OP's dropped out of the bracket and dragged the drain pipe off when it contacted the road.
