Grey Waste Tap (1 Viewer)
John&Kate
310
266
Waterlooville
Since Sept 2015
Hi Funsters
Been getting some dripping from behind the grey waste tap of late.
Took apart the fittings today to discover that the grey pipe leading into the tap fitting had at some point been broken and a sealant was used to join into the tap to stop any dripping.
This sealant has now failed as its dripping.
I plan to cut out the broken section of pipe and re-join to the tap, my question is should I use anything like a solvent cement to join the pipe to the tap fitting or is there a preferred sealant any one can recommend ?
Many Thanks John
DanielFord
3,020
3,086
I just pushed ours together when I replaced it. I used trusty duct tape at the tank end to ensure it didn't fall off again!
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
Mines been held on with duct tape for over 5 years since I broke it completely on some rough ground. Doesn't leak at all.
Minxy
32,646
66,530
E Yorks
Carthago Compactline
Hi Funsters
Many Thanks John
I suspect it was a previous owner with a 'stealth dribble' ...
keith
3,421
1,864
Ecclefechan
Autocruise Starseeker
I thought they were all built like that, :rofl::rofl::rofl:
Ridgeway
3,656
6,151
Lausanne
NiBi Arto 85E
Since 2012
If you want a permanent seal then something like Griffon Uni-100 or Tangit (from Henkel) are good products, Screwfix has their own version of these and it's also perfectly good.
I'm assuming this is a PVC or U-PVC joint ?
Minxy
32,646
66,530
E Yorks
Dripping? Did I hear DRIPPING?
I used to love it on toast.
OOooooooo ... I haven't had any good beef dripping for years! Used to love it on hot toast with a little bit of salt .... mmmmmmmmmmmmmm.
Badknee
7,407
412,580
notloB
Vantage Neo
Living the dream.
I've read about that stuff in history books...... honest. :whistle:
John&Kate
John&Kate
310
266
Waterlooville
Since Sept 2015
Thanks for you responses.
I have "push-fit" it back together at the moment and all seems ok .. ..
Some real signs of age being displayed, I know that my NAN still has dripping on toast :sick:
