So this is a minor problem but one I would really like to sort at some point soon just so everything is ship shape Bristol fashion.
My Grey water drain pipe leaks from the connection to the tank (external). I had to replace the pipe shortly after buying the motorhome last year (was a year old then) because it split due the swinging motion of the arm to lower the drain tap to open.
I went to my local caravan supplies shop (Towsure) for a replacement but it just won't make a good seal. Mainly because its really poor rigid plastic and the motion of swinging the arm up and down wiggles it too much at the connection and it just leaks.... I have tightened the jubilee clip as much as I dare without doing damage to anything and thats all I think I can do really. Ideally I think I need a more rubbery hose pipe type thing so its got a bit of elasticity to it for the swing & seal.
Anyone suffer the same issue and sort it? currently it just dribbles its contents out on the ground which is not ideal for been a friendly camper.
