Grey waste exit valve in centre of van (1 Viewer)
Jul 24, 2018
47
28
South Yorkshire
Benimar coachbuilt
Since 2018
Hi,
First post since joining a while back, but can anyone help please?
We have a Benimar Tessoro which we love, but the grey waste exit valve is on the centre line of the van which means we have to seek out places with drive over facilities. We are finding this restrictive. Can anyone suggest ways of converting the knife gate valve to a more useable system, e.g. pipe to the side of the van as seen on many motor homes.
I am a capable diy’er ::bigsmile:......up to a point:rolleyes:.
Grateful for any thought or assistance.
Thanks,
John
Jan 8, 2013
8,478
11,516
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
Find the size and ask at your local plumbers merchants about solvent weld waste pipes.
Or on line - mine is 40mm diameter
6,800
7,837
Manchester
A class Hymer
Since the 80s
In case you're confused, there are two types of PVC/ABS pipe. Waste pipe is thin and not designed to take high pressure. Irrigation pipe is thicker and will take mains water pressure without problems.
Waste pipe is fine for MH waste systems. Some of the items in the picture, like the valve and bends, are high pressure irrigation pipe fittings. Irrigation pipe fittings are often difficult to find in UK DIY stores.
J
Jul 24, 2018
47
28
South Yorkshire
Benimar coachbuilt
Since 2018
Thanks, Stealaway! As it happens you’re just down the road from me so would be nice to meet and view /discuss, if that’s ok with you, subj to masks etc.!
2,920
4,215
Wells, Somerset
Elddis 115
since 2004
Hi,
Thanks,
John
Ours too, though not a Benimar. it's such a pain. But ours has a sliding open/shut valve, I guess yours must too? By the time you've added more pipework, it'll be too low and will ground easily?
J
Jul 24, 2018
47
28
South Yorkshire
Benimar coachbuilt
Since 2018
Thanks WynandJean, food for thought though I am not confident with 12v electrics.....but have a mate who is!
1,367
3,315
Chandlers Ford, Hampshire
Burstner TD700 H L
Since 2008
Hi,
Thanks,
John
JB30 See this link to my post , after the tapered pipe I added a flexible hose. (y) Pipe
6,779
12,489
Herts.
Adria Coral lowline
Your options are going to be defined by what you currently have fitted. There is no point installing 50mm pipe, if the valve you’ve got is 15mm.
Stick a pic on of what your current setup is, and you will get better advice 👍🏻
J
Jul 24, 2018
47
28
South Yorkshire
Benimar coachbuilt
Since 2018
Hi Landy Andy - will get some pics on when I’ve a mo, in the meantime I’ve had a crawl under the van and the down ward facing outlet is 40mm internal, 49mm external
6,779
12,489
Herts.
Adria Coral lowline
That’s a great start. Some vans have a tiny silly small flex pipe.
179
334
Ynys Môn, UK
2016 Benimar 243
Since 2016
Most common adaptation on a Benimar, simply add some pipe work and continue to use the existing gate valve. Benimar uk owners on fb is a great resource for info.
4,157
5,098
Market Rasen
Self Build
Since 2003
Had the same problem under a Burstner a few years ago so used to carry a length of plastic pipe with a funnel stuck to the end.
J
Jul 24, 2018
47
28
South Yorkshire
Benimar coachbuilt
Since 2018
Ratcatcher, can you tell me what exactly is the 90 degree bend attached under the gate valve, and how is it secured (or is it just the pipe clip holding it up?)
Thanks again
179
334
Ynys Môn, UK
2016 Benimar 243
Since 2016
The photo is from the fb Benimar uk owners site, on mine I used standard waste pipe fitting from my box of bits in the shed, the hole in the tank is slightly too small for the pipe to push in, so I slightly chamfered the pipe until, it was a tight fit, the the pipe clip holds it in, here’s mine just standard 40mm waste pipe and fittings.
Lenny HB
52,688
147,610
On the coast in West Sussex
Hymer B678 DL
The photo is from the fb Benimar uk owners site, on mine I used standard waste pipe fitting from my box of bits in the shed, the hole in the tank is slightly too small for the pipe to push in, so I slightly chamfered the pipe until, it was a tight fit, the the pipe clip holds it in, here’s mine just standard 40mm waste pipe and fittings.View attachment 469068View attachment 469069View attachment 469070
UK 4Omm pipe is not the same o/d as contenental 40mm pipe CAK Tanks sell the correct one.
wuzzlewood
107
85
Gower
Bailey Autograph 3
since 1990
Irrigation fittings or the equivalent can be bought in most garden centres in the water garden section! They are used for the large filtration systems used for Koi carp!
125BEER
1,101
2,886
PLYMOUTH
BENIMAR MILEO 282
Since 09 2018
I use a flat 40l water carrier,slides underneath (wheels off)nicely.
Have seen Benimar forum adaption which might do at later date.
2,893
2,626
Newmarket,Suffolk
Benimar294
Newbie
I also have a benimar, I had a hose from a old Hoover that fitted perfect, I used it a couple of times on the drive, then thinking I would never use it, I threw it away, I’m still regretting throwing it. 🤣
Mickey.
mikebeaches
5,346
8,469
Bristol
Rapido V68 Van Conversion
Since 2009
Some of the images I'm seeing in this thread look very innovative.
BUT the resulting systems look oh so vulnerable to being knocked off on the first piece of uneven ground or aggressive speed bump encountered.
Admittedly, our previous coachbuilt had reasonable ground clearance. But I find the current PVC restricted on that score. Have already wrecked an electric step going over a traffic calming hump at circa 12mph. :rolleyes: :(
63720
As said above, extend the pipe, to the side of the van with similar, fit a manual valve and a 90° bend on the end then leave the centre valve always open. Worked for us.
