Grey and Black water (1 Viewer)
Twiggy
Banned
Aug 30, 2018
10
Hobby
Just starting out!
OK, new to this malarkey....want to be environmentally responsible as far as possible, but also practical.
Grey water
Does this get discharged into a tank, or do you need to put a receptacle in place to receive it?
Where is it appropriate to dispose of this waste?
Black water
OK, I get it that the heads empty into the cassette. Confused as to the whole chemical/no chemicals/laundry stuff????
SOG thingy? Pro’s/con’s?
Where can you legally/ethically bin the contents? If you are not on a site, is it appropriate to sling it down a (public) Kharzi?
And WTF does an Elson point look like?
Cheers,
Twiggy
scotjimland
2,309
9,976
A Woosh bang
7,234
20,094
Barnard Castle, UK
Concorde Concerto
Hello
Grey tank, all sites have an emptying point so drive to and get the pipe outlet over the years then pull the lever. Use a bucket to carry it to the drain to save you moving.
Toilet have a specific emptying point on site, off site, if using a sog then you can empty down a toilet as no chemical is required so a sog a good idea.
That's the short easy answer but threads like this does cause huge difference of opinions, a few sites say dispose of grey water in hedge bottom, others say it kills the plants.
Be responsible whatever you do.
By the way, do you like debating as it you do you have started a great thread.
scotjimland
2,309
9,976
A Woosh bang
wasn't going to get drawn into this debate, it has been discussed at great length, all I would add to the previous reply is ,
I assume you haven't bought a camper van yet... so regarding grey, not all have a built in grey waste tank.. most do, but smaller camper vans may only have a pipe which you should place in a bucket or waste container.. in either case it should be disposed of in the facility provided by the site.. some have tanks.. smaller sites , like CLs will generally ask you to depose of in the hedgerow..
there is top advice in this article about Grey and Black waste disposal wild camping
Reactions: GJH
GJH
29,450
38,827
None, now sold
2006 to 2022
Some notes Here.
Unless it is specifically indicated that you can, no. In general public toilets are not designed for that use. Others will disagree but that is par for the course when they are making excuses for their behaviour even though they know they are not on solid ground.
Various different designs but on any site (including rallies) they will be well indicated.
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Picture of an elsan point..
All much the same. emty black waste down for a better word a hole in the ground which takes your waste away..
They come in all shapes and sizes...
Grey waste, we ask people to empty on the established plants and bushes... contrary to what some say... it will not hurt the plants...
And through this summers draught it`s probably what stopped a lot of our plants dyeing..
funflair
19,337
30,187
Guisborough
MORELO palace
since 2012
Well this seems to be going well so far so to add to your education, the "SOG thingy" is quite simply a fan that draws air through the toilet cassette when you open the flap to use it the air help to break down the solid is the cassette and has the added bonus of ventilating and unwanted odours to the outside, most but not all SOG's have a charcoal filter to neutralise the smell before it gets into the atmosphere and under your neighbours awning, if you want to stay friends with your neighbours this filter needs changing (I do every 6 to 12 months) if there is a rectangular SOG outlet on the cassette compartment door the filter is in this otherwise it is sometimes an inline filter.
Chemicals/laundry stuff? some people think the contents smell better if you add these things personally I think it still smells like a bucket of ---- whatever I put in so now I just put in No1's and No2"s, if you use the blue chemical you need to be careful if you empty into a septic tanks or treatment plant as the chemicals can kill the enzymes that do the treatment work.
Martin
T
Twiggy
Banned
Aug 30, 2018
10
Hobby
Just starting out!
Thanks Martin. Starting to get my head around the SOG bit - so does the inside end of it connect to the cassette?
Twigs
scotjimland
2,309
9,976
A Woosh bang
Twigs
yes..
On mine , a C200 , you remove the pressure relief valve and fit a pipe adapter, supplied with the SOG kit..
only recently fitted mine.. easy job.. the fiddly bit is fitting the micro-switch to start the fan when the blade opens.. the SOG instructions are good and easy to follow.
There are different kits for different models of cassette
SOG kits and parts here .. this was the cheapest seller I could find.. https://leisurelines.net/index.asp?function=search
