bolicam
thanks
Bob
If it's a stuck relay, both batteries will be at the same voltage, because they are connected together. Can you check the two battery voltages to see if they look the same or different?Looking at the diagram I'm guessing that light shouldn't be on if the engine is not running, could be a stuck relay.
