- May 29, 2013
- 2,769
- 21,308
- Chausson best of Flash 10
- Several years now
I bought this heater a couple of years ago, only about £10 and finally got around to mounting it in the MH.
What a great little heater ! It's only 500w so won't trip any site supply. It has a two speed fan and a setable digital thermostat. You can set it to run for up to 9 hours, so set it to your desired temp go out for the evening and when you come back it should be at the same temp for you (depending on size of MH and outside temp) or set it to come on in 9 hours time so you could wake up to a warm MH. I had a look inside and it looks well made.
Anyway, It comes with an integral plug which mounts it, but I threw that away and mounted it on a bracket fixed to a solid shelf, the Chausson plastic bits are too brittle to bolt anything to. Right now I just have a mains lead to it, but over the winter I'll take the lead inside the bodywork to a mains supply.
Its brand name is Beldray if anyone fancies the same.
