Hi Folks
My water tank gauge said the tank was at 50% so I decided, seeing as how I'm away for a couple of days, I would fill it up. So stuck the hose (softened water) into the leetle hole and, because our water pressure is rubbish, walked away to do something else. While I was away the tank filled up and water began running out of the filler hole. Turned off the hose and then noticed there was something dripping down underneath the middle of the van. Went inside the van and there was a large pool of water in the dinette and under the seats. Water EVERYWHERE!
Horrified, I quickly cleaned as much of it up as I could then, remembering that the fresh water tank is underneath the seats in the dinette, I lifted the cushions, unscrewed the wooden cover and saw that the water was leaking out of the top of the tank, through the large screw-in plug on the top of the tank. (See pic for an example although this is not taken from my tank).
I was under the impression that these plugs are sealed and will therefore not leak. However, if I press down on the tank I can hear air whistling through the seals on both plugs on the top of the tank.
Is this normal or should I be yelling loudly at the dealer I bought it from (or Dethleffs!)?
Chris
Chris
