GlobeCar Campscout - tap connector come loose ?
mickcope
essex
hi top
Help needed - on the bathroom tap (Globecar Campscout) the cold feed under the tap has come out. But I cant get my hand in the tight space to it to push back. The vanity unit seemed sealed and the tap seems to be glued to the unit. Any thoughts welcome ...
Mick
Child’s hand?
Long nosed pliers?
i was going to say there is a plate missing that holds them in place but looking at the picture it looks like there is a pin that should sit in the grove on the white part below the o ring you may need to remove the pin to reassemble unless its spring loaded?
You need to remove the silver pin that you can see in your photo, so if you can’t get near enough to the pipes you are going to have to remove the tap. Best way would be box spanner.
the problem is the underneath is fully boxed in - so think I will have to disassemble the vanity until to get to the tap base cheers
Is the tap fixed to the basin?
If so just remove basin.
Top photo would help.
