- Dec 31, 2010
- 1,293
- 2,366
- Malibu I500 A Class
- Since 2010
I get exactly 25amps when watching the smartshunt on the victron connect app when I start the van so I am receiving the full outputWorks the same as most other EBL, the way yours is wired the split charge relay is in parallel with the B2B effectively shorting out the B2B making the B2B pointless.
I suspect that it was an easy way of fitting the B2B which is needed for the smart alternator.
I'm fairly sure you will get a better charge rate if you wire it correctly. All you need to do is disconnect the two wires from the starter battery input and connect them together.
