JJ
Mágica
- May 1, 2008
- 19,252
- 47,931
- Burstner Privilege T
- over 50 years
And nothing that can't be managrd without one.
I very, very, very strongly disagree...
JJ
Sorry, but I disagree, most generators only give 8 amps at 12 volts and most mains chargers in vans between 15 and 20 amps and modern ones are better regulated to put the first 80% in at near maximum amps. So the mains will win. Of course you can use both. There are specialist 12 volt generators giving around 50 amps but the ones i hsve seen seem noisier than the suitcase ones.
Personally I find the noise of a modern suitcase generator much less disturbing than either a couple of screaming kids, or a few pissed motorhomers shouting the afternoon away.
That's better
Most generators give 8A constant (give or take) because the open circuit (unregulated) voltage is 18v to 20v. I take your point about modern PSUs though - I had in mind earlier 2-stage versions.Sorry but bollocks most generators only give 8 amps at 12 volts and most mains chargers in vans between 15 and 20 amps and modern ones are better regulated to put the first 80% in at near maximum amps. So the mains will win. Of course you can use both. There are specialist 12 volt generators giving around 50 amps but the ones i hsve seen seem noisier than the suitcase ones.
If course there isn'tI very, very, very strongly disagree...
JJ
If you need 240v plug in to electric
Nope it's factWhat a silly post...
Probably a wind up...
JJ
If you can't manage in a van without 240v then go to a site that supplies 240v
I have good idea ...i know some people need 240 to operate medical equipment etc.I shall not get into a long explanation except to say that you have absolutely no idea.
Nope it's fact
I said any use for a generator can be got around using another method.
You said it couldn't.
It can ....connect the van to 240v
And a woman using a generator to run a hair dryer comes under reasonable, hahaThere is always a choice, If you want to use a generator reasonably with regard to people around then that is your choice.
If for some reason you can’t stand anyone using a generator even reasonably then you have a choice, you can go to a site which does not allow generators.
Simples
Best Wishes Tony
If it floats your boatAnd a woman using a generator to run a hair dryer comes under reasonable, haha
These Guys. seem to know their stuff.:- http://www.aandncaravanservices.co.uk/generators.php
Its a website worth bookmarking for all sorts of R-V electrical and Battery info.
There speaks an honest and wise man.I suppose the answer to that is a resounding YES!. Especially if YOU not the complainer, has to live with said "person"!!!. FAR better IMV to upset half a dozen "Campers" for a short period, than suffer at the hands of one who is in a "Bad Hair Day" Mood!!
