Can anyone help looking to buy a generator for our motorhome any recommendations
You might be opening a can of worms with that question. LOL. But anyway, depending on the power you need to generate it's probably going to be a 1kw or a 2kw genny.Can anyone help looking to buy a generator for our motorhome any recommendations
@Mart grump Just to clarify most gennys reduce their revs when power draw is reduced, I think most call this eco mode.The revs will reduce as your batteries reach charge.
Only inverter generators, cheaper mechanical generators run at a constant speed.of 3000 rpm (50Hz) no matter what the load.@Mart grump Just to clarify most gennys reduce their revs when power draw is reduced, I think most call this eco mode.
Or it is on my Hyundai
Best Wishes Tony
That is quite true pappajohn but I assumed "yes come on with the jokes" he would only be looking at an inverter generator as I would think he would want it to be safe for chargingOnly inverter generators, cheaper mechanical generators run at a constant speed.of 3000 rpm (50Hz) no matter what the load.
Might want to look at these so the rocks your nearby campers throw dont break the windowsCan anyone help looking to buy a generator for our motorhome any recommendations
A couple of Honda generators for sale in the for sale adds on here.Can anyone help looking to buy a generator for our motorhome any recommendations
What do you want to power from a generator?
I myself have a Hyundai 2.2kw with electric start which comes in handy with my back the way it is, because of the extra start
That’s no good. He needs the generator to run a fan heater to warm up the cheap butane gas bottles he has brought which are not gassing off in this cold weather. HahaHonda with lpg conversion.
got a Honda EU10i for sale as newCan anyone help looking to buy a generator for our motorhome any recommendations
Had a look at these, seems good value. any downside?. SWMBO`s needs are only going to get greater, as we inevitably age. And we seem to acquiring more power hungry stuff all the time. BTW, I assume the Extra should be Electric? Bloody spellcheckers!
Interesting that. Non-inverter generators output a true sinewave and are completely safe with sensitive electronics. But, and it's a big but, they can cause damaging surges when equipment connected to them is switched on or off. So, for example, a sensitive, low current, device might be badly affected by a microwave switching off. An inverter generators output is as good or bad as the inverters filters and could be "modified sinewave" or pure sinewave. I don't know how the various inverter generators describe themselves but what applies to any inverter applies equally to the generator variety.That is quite true pappajohn but I assumed "yes come on with the jokes" he would only be looking at an inverter generator as I would think he would want it to be safe for charging
sensitive elctronics, all the ones I'm talking about are what are called suitcase gennys and all inverter gennys.
Best Wishes Tony
