ok thanks for all the advice have decided on Honda but should it be a 10i or 20i we will be running tv lap top lights phone chargers
Hi Mart grump just curious why you started a new thread and did not reply to the original one you started ???ok thanks for all the advice have decided on Honda but should it be a 10i or 20i we will be running tv lap top lights phone chargers
Away for 4 to 5 days we have two batteries in our Carthago just looking for a back up just in case
Your money, your choice but there is a reason why many people have generators for sale and many people comment that they only fire theirs up once a year ...
Yes and one is nearly new, he'd be getting abargin with that one.As I said before there are 2 for sale in the for sale adds on here.
You've got a built in emergency backup already, which you've paid many many tens of thousands of pounds for. Your motorhome engine.
If you your leisure batteries ever got too low, you can use the vehicle engine and its alternator to charge them.
If you are worried about consumption of your 12volt system, just add a big solar panel, and if possible an additional leisure battery.
Cost of both would be less than a generator; there's No NOISE to inflict on everyone else in earshot its a FIT and forget system, the weight will probably be less, no dangerous petrol to carry, no generator smell to have in the MH, and it even keeps your batteries topped up when you aren't using the MH.
Mind you regular running of the diesel engine is likely to cause glazing of the bores which will impact on performance and cost more than the cost of a generator to fix. Fine as an occasional fix but not a good thing .on a regular basis. Also I think most would find my little Kippor a lot less intrusive than my 2.4 diesel. I do also have 200 watts of solar so my baby genny is a last resort.
Ice cream vans do ok on tick over all dayMind you regular running of the diesel engine is likely to cause glazing of the bores which will impact on performance and cost more than the cost of a generator to fix. Fine as an occasional fix but not a good thing .on a regular basis. Also I think most would find my little Kippor a lot less intrusive than my 2.4 diesel. I do also have 200 watts of solar so my baby genny is a last resort.
There seem to be a lot of very low use secondhand generators for sale !!!!!!!!!!!!
For this usage you will not need a generator, especially if you get some solar fitted. When we are away in winter skiing, we spend several weeks off hook and use a 750 watt honda, which runs everything, including the heating fans, so as said above, the 1.0 unit will be very adequate - but you are unlikely to need it!Away for 4 to 5 days we have two batteries in our Carthago just looking for a back up just in case
this will keep you going
this was it running. noisy bugger!
