Saltings
Hi Lenny
My thoughts are there is a fault in the electrics as the fridge runs OK on both gas and on EHU. In addition the PV cells will not charge the HAB or motor battery.
Re: the other seat: Never taken this out but should be possible although it does not swivel which is necessary to remove the one under the drivers seat (Fiat Ducato). I have enough fun with one battery let alone 2!!
The charger I use is the CTEK MMS 5 which has a setting for AGM but not GEL.
Which GEL's do you use?
