Gel coat repair (1 Viewer)
Dec 1, 2016
23
21
Perthshire
Kon Tiki G649
2 years
Any advice from you experienced guys out there. I've just damaged my Kon Tiki on the eaves of my house (you can never relax can you?). Local repairer wants to do a fibreglass repair and paint which doesn't seem right. She's quite a new van, 2017. He says I won't get a proper gel coat repair in Scotland, obviously where I live. Is it easy to do yourself? Attached a pic which makes it look a bit worse than I feel it is. Any suggestions? Cheers.
Dec 6, 2011
11,589
25,411
South Wales
Coach built Adria
i guess there are a few boat yards in Scotland. that would be my port of call ( Pun intended ;))
they are generally expert at gel coat repairs of boat hulls and cabins.
Nickg
Dec 1, 2016
23
21
Perthshire
Kon Tiki G649
2 years
Lovely pun Phill, cheers. It's the usual, I'm not near anything!
Dec 6, 2011
11,589
25,411
South Wales
Coach built Adria
a phone call to one of them for a bit of guidance might give a glimmer of whats the best type of repair.
Nickg
Dec 1, 2016
23
21
Perthshire
Kon Tiki G649
2 years
Thanks Phill, much appreciated. I'll try that. Open to all suggestions. Once I've stopped kicking myself! I only moved it to clean the driveway!
Dec 6, 2011
11,589
25,411
South Wales
Coach built Adria
as you say Nick, cant relax for 1 second. good luck. just need to keep the gash clean now pending repair.
please let us know how it was best reapired..... might need it myself :cautious:
Camping Gaza
993
1,467
La Châtre, Centre-Val de Loire France
Coachbuilt Low profile
Converted a Fiat Ducato PV a while back
Actually it is very easy to do yourself, I totally destroyed my rear light surround and rear corner bumper, smased like glass in several bits far worse that yours. Fixed mine ok myself
As yours is just a cracked surface remove what you can and use gel coat filler, glass mat, and sand with wet and dry. Finish with matching spray paint.
Drill small 3mm holes at end of cracks before filling to stop cracks spreading in time.
easy and you will never see it
May 7, 2016
7,248
11,731
West Sussex
Carthago Compactline
Since 2003
Not something I would attempt but a boatyard that specialises in gelcoat repairs should do a good job.
Lenny HB
53,417
149,915
On the coast in West Sussex
Hymer B678 DL
Took a bit chunk out of the front of my last van. Local boat repairer did a superb job.
The problem with doing it yourself is matching the gel coat colour, although you could spray it, far better to do the job properly with matching gel coat.
Nickg
Dec 1, 2016
23
21
Perthshire
Kon Tiki G649
2 years
Thanks guys. Might try it because of where it is. Not easy to see from the ground. Doesn't have to be perfect but I will make other enquiries too.
3
34127
Many years ago when sailing, the boat I was in got badly holed by another boat. The damage was quite bad but a local boat builder sorted it out and somehow managed to spray the gel coat finish onto the hull and it looked like new and very hard to see the repair.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I tried local boat builders for a rear skirt repair recently because i was advised a gelcoat repair would be best (I agreed). The only two to have a look wouldn't touch it because of the labour involved in the finish. So I'm doing it myself.
May 7, 2016
7,248
11,731
West Sussex
Since 2003
Sometimes the skirts are plastic not fibreglass, which might not be a boatbuilders speciality. When I had a damaged rear skirt the repairer said they were designed to be replaced rather than repaired, which surprised me because it didn’t look that impossible. I didn't argue because CalMac was paying.
A boatyard specialising in osmosis treatment might be a good place to look because they are specialists in repairing and matching gelcoats.
H
Hagstrom
I've just repaired my holed and torn fibreglass rear apron corner and would recommend trying it yourself. For the surface finish, I used gel coat repair stuff from a tube, with accelerator.
I saw a YouTube video about using superglue's capillary action to seal cracks in the gel coat. It's worked for me so far, in that the cracks haven't spread.
If you can't see the repair unless you're 8ft tall, I'd use aerosols for the base coat and the clear coat.
Mar 10, 2016
558
617
Scotland
A Class RMB 750HE
Three years and counting, 30 years a tent tower.
Nickg J Borthwicks at Newton St Boswells here in the Borders did an amazing job on RH after a run in with a tree branch. I cannot see where the repair was done. They do commercial vehicle repairs (and servicing) and are familiar with this sort of repair. Commercial vehicles use the same sort of panels etc as motorhomes do nowadays.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
It is GRP.
PrincelyBindle
I'm a newbie
Boatyards which are good at Gelcoat repairs can do this job.
Robmac
193
2,523
Wyboston, Bedfordshire
Renault Master self build
On second van now since 2012
Here's how it's done;
Obviously this is only a small repair but I have seen the same method used for larger repairs like the damage to your own.
I have a small repair similar to this in the deck of my boat which I haven't got around to yet, but I will be using this method.
Best of luck with it.
Lenny HB
53,417
149,915
Hymer B678 DL
I don't think much of that method.
Whenever I've used Gel Coat I try to fill the hole exactly then smooth sellotape over the top, peel off when dry and with luck a perfect finish, if it does need sanding I use 3000 grade wet & dry.
As for him using 180 grit paper, unbelievable, that will wreck the surface. I wouldn't use anything less than 2000 grade on Gel Coat.
Robmac
193
2,523
I can only say that I have seen this method used many times with great success. Any sanding should be kept to a very local area as he did in this video, and you can see that he didn't wreck the surface..
It is important to gradually use a smoother grit though, but I have always been told to leave a proud surface and then wet and dry because the compound will shrink during the drying process.
I have only watched this process at my local marina and haven't actually tried it myself, so I will soon find out!
