Be sure to only “part fill” on the first fill.Hi just had a gaslow fitted and was wondering if it is better to fill up here or in Spain when we get there on the 25th, it will be the first time I have used a gas pump so any tips would be helpful. Tia
Why??Be sure to only “part fill” on the first fill.
To ensure the 80% safety system activates properly.Why??
The 80 % safety cut off won't work if you part fill. With gasit you are advised on the first fill just to put in a couple of litres so you can check for leaks.To ensure the 80% safety system activates properly.
You should have been told.
I'm surprised that where you had it fitted did not partially fill it for you or, at the very least, advise you on how it worked?Hi just had a gaslow fitted and was wondering if it is better to fill up here or in Spain when we get there on the 25th, it will be the first time I have used a gas pump so any tips would be helpful. Tia
Just as important, is if you have a leak in your system and it cant be fixed easily there wont be too much gas to escape.To ensure the 80% safety system activates properly.
This doesn’t say anything about part filling..? It does say to pay attention to the capacity that is going into the cylinders to see if the 80% shut off is working and of course it will never work unless it is completely filled….
I wonder if Basildog could clarify it for us then, as I must have clearly misunderstood what the man from Gaslow told me at the NEC.This doesn’t say anything about part filling..? It does say to pay attention to the capacity that is going into the cylinders to see if the 80% shut off is working and of course it will never work unless it is completely filled….
I’m afraid I wasn’t standing next to you at the stand, I’m only going by the information you posted…I wonder if Basildog could clarify it for us then, as I must have clearly misunderstood what the man from Gaslow told me at the NEC.
