If you go to the gaslow website there is info on there, advises percentages full to nearly empty on the colour scales on the gauge. Can't do links, sorry.
When it is fitted to the bottle, which is then turned on, the red section shows as green (as long as there is gas in the bottle)and when the gas gets used up the red section shows again as it gets low.
The gauges are inaccurate but at least they do indicate that you have gas in the bottle. When on green they are reasonably full, but when starting to show red, they soon run to empty, so an indication to refill ASAP. My gauges show green, yellow and red, once they get to the tail end of yellow there isn't much gas left.
