It would help if you provided a bit more information. i.e. How is your motorhome currently set up ? What system do you have fitted ? If its Gaslow then you need to get a pipe that screws into your filler point and a connector for the bottle. Both these are available on the Gaslow web site or the website your set up is from. If not have a look at the Gasit website (https://www.gasit.co.uk/) everything you need will be available from there. They will also explain everything to you if you need it spelling out in simple terms. They are holiday at the moment but there website is active. Best of luck.Hi my Motorhome is using propane at the moment if I change to butane do I just change the bottle and regulator
Why would you want to change to butane another month or so you will need to change back to propane.
But you live in the south of France Steve, when traveling across Spain from the north nightime temps can be down to zero even in April.In Spain I have found that they will not swap a butane bottle for a propane or other way, unless you have very good Spanish and know how to pass a folded tenner to the right guy. But for a tenner you might as well buy another bottle. Never needed propane in Spain in winter yet. But now have refillable's.
If you have a bulkhead regulator then you need to get a different connection which looks like a Spanisg regulator but is just a tap, "detonder" or something like it in French don't know the Spanish name.
Best of luck.
Steve
If the Moho has a fixed regulator, take your Spanish cylinder to a good dealer and buy a suitable adaptor which is what you need. Not another regulator. It will probably be a Gaslow product. Also have a look at their catalogue on line. That may tell you which one you need. MikeI bought a second hand spanish gas bottle with regulator but it is butane. The bottle is exchangeable not refillable
