Gas problem with Hob & Fridge (1 Viewer)
George Thomas
43
34
Bognor Regis
Rapido 7099f 2006
Since 2014
Hello all - hope you are keeping well. Advice please. We have two gas related problems on our Rapido. We live in Bognor Regis. So looking for engineer to look at & repair. Mobile or workshop please.
1. With the 3 burner Dometic hob - two burners play up - difficult to light & unreliable. This has been a re occurring problem.
2. With Dometic 3 way fridge freezer. Will not fire up on gas. This is a totally new problem.
Look forward to your information.
All the best.
Nikki & George
32,629
66,498
As 2 appliances are affected try changing the gas bottle to see if it's the gas, alternatively if you have one, try another regulator.
11,953
16,567
If by playing up you mean they'll light & stay lit until you let go of the knob the problem is likely to be the flame failure device (a small thingy sticking up adjacent to the diffuser rings). Does the fridge attempt to start on gas - you'll hear the clicking from the igniter - or does it do nothing? Is it an AES fridge?
Edit: Or as Minxy Girl suggests check out gas & regulator first ;).
Jun 29, 2015
3,470
57,290
Southampton
caravan (for now)
on and off since 1984
Need a bit more information .
Does the third burner light and burn well? If it does when it is alight and you try to light another burner does the lit one change the flame?
Does the fridge try to light?
Does it light and go out?
MisterB
5,860
13,106
Adria 670 SLT
does the fridge light go off when you close the door ...... :LOL: :LOL: :LOL: :LOL: :LOL:
seriously as everyone suggests, check gas supply first, if all is ok then do the tops of the gas burner come off for cleaning, gunge can accumulate and stop the gas coming out where the flame failure device is and tricking it into thinking there is a fault in the gas supply
Mar 11, 2013
48
65
England
since 1990
Last year, I had a fault on my Dometic fridge/freezer, model No RMD 8505, which would not light in gas mode. Changing the electrical control module solved the problem and the unit operated normally in gas mode. Yesterday, following 8 weeks of lockdown, I decided to check the fridge/freezer in preparation for easing of the restrictions for Covid-19. The fridge/freezer would not ignite in gas mode. The only component to left to change, is the gas valve, GV-100. Any one else experienced this problem?
Oct 11, 2016
1,316
2,196
Bognor Regis
Bailey Adamo 69-4
6 years
I'm sunny Bognor too. We keep our MH in storage at Church Farm, Bosham. They have Meridian Motorhomes on site and they have done work for me in the past. The site is in lockdown so they may not be open. There are also 2 other dealers close by but I know that they are not open.
MisterB
5,860
13,106
Adria 670 SLT
quite often spiders are the culprits in the flame failure device (ffd) supply. they nest over winter and die often blocking the gas jet that impinges on the thermocouple. because the flow of gas is restricted it doesnt provide enough 'wooomph' (technical term !) to heat the thermocouple enough to send a signal back to the main gas valve to tell it to open.
whenever there is a definite gas supply and a flame failure device is fitted, then the first port of call would be to check the thermocouple/ffd
