Gas Pressure (1 Viewer)
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Since 2010
We have poor gas pressure to our hob, oven and I suspect the boiler. Other motorhomers have suggested we need a new regulator. We have Gaslow with automatic changeover. Do we need a special bit of kit for this? Advice please -
Thank you
Mags
Oct 26, 2021
64
55
Petersfield, UK
Hymer B574 A class
A returner after a 10 year gap
My regulator is on the output side of the Gaslow installation. If your is the same you just need one with the correct threads (and pressure).
Basildog
2,219
3,636
Thank you
Mags
Ideally post a picture of your existing installation / regulator.
So many different types available and always easiest to replace like for like if possible.
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Here is the (apparently) offending regulator. What should we do to replace it? Thanks Mags
Basildog
2,219
3,636
Looks like a pretty old Cavagna regulator
We have the modern equivalent in stock , should be an easy swap, you won’t need the test point connection, new regulator should fit straight on to the silver nut in your picture.
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
Thank you. M
Basildog
2,219
3,636
Should have asked - what is the name of the product we should order please?
I can’t quite make out what size pipe you have so ideally measure the black steel gas pipe the can side of the existing regulator, other side of the silver nut .
It will be 8 or 10 mm
Sep 17, 2020
951
3,156
Totton
Bailey Autograph 745
Since Sept 2020.
For what it's worth we had exactly the same issues at our static van last week. Different system, but swapping out the regulator sorted everything out.
