brynric
We have 2 Gaslo cylinders, one larger one smaller that we filled in the UK. Travelling through a very cold France and Spain the larger one was nearing empty and we stopped at a garage to refill.
Then the oddity.
The heater is timed to come on early morning using the larger gas bottle, and so it did for 5 minutes then stopped with a 202 or 112 (gas switched off) code. The fridge still worked as did the stove.
20 minutes later the heater worked again on gas, for 5 minutes. Later in the day the heater was fine. If I switched to the smaller (UK filled) bottle there was no problem.
I think this may be the issue that the Spanish use a higher percentage of butane in their lpg and it wasn’t gassing sufficiently for the heater until it warmed up.
What does the panel think?
Then the oddity.
