Gas leak? (1 Viewer)
Aug 3, 2015
99
117
Shropshire
PVC
3 years campervan, many as a tugger
The gas bottle box on my pvc always smelt vaguely of gas and despite checking very carefully for leaks the smell has persisted. I have an lpg convention with refillable gaslow bottles and have now taken the system out to transfer it to a new (to us) Rapido.
I have noticed that the gas smell is now in my garage where I have stored the tanks and pipes. Has anyone any idea why this should be? Do the flexible pipes absorb the gas smell and this leaches out through the rubber. The pipes are only 2 years old and show no signs of cracking. The gaslow bottles have been checked and show no loss of content.
Please advise if you can because I am mystified.
Aug 6, 2013
11,941
16,532
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The gas does leech out through the rubber (very, very, slowly) but in addition if the pies are disconnected the scent absorbed by the internal pipe walls will cause smells. The stuff that's added to LPG to give it a pungent odour is very pervasive.
Feb 9, 2008
8,924
18,663
Corby, Northants
Coach Built
Pressurise your system then use a mix of water and washing up liquid to find any escaping gas. Very effective and cheap method to find leaks.
two
Aug 4, 2011
4,901
4,560
West Midlands
A-Class Fiat
It doesn't take much gas for the smell to be noticed; that's the idea of it. If there's a leak you should be able to get bubbles. If the smell is not strong or strengthening, I'd not worry once you've checked the obvious sources.
Oct 7, 2013
5,867
36,736
South Wales
Swift Escape Compact
Since 1988
Can you part fill a dustbin with water and dunk the entire gas bottle? If there any porous areas on the bottle you should see bubbles.
two
Aug 4, 2011
4,901
4,560
West Midlands
A-Class Fiat
Gas detection spray might be easier. Comes in an aerosol and you spray it about liberally. You'll get foam if there's a leak. It could put your mind at rest.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Think me absolutely crazy (or actually Swmbo) but we had a smell of 'gas' just after we'd come back from a few days away but crucially 2 days before we were going away for 6 weeks.
Panicking, I took it to Rhino Installs. We have stainless steel pipes.
Full check of bottles and system and no fault.
I reckon (as I said at the time), it was the smell from the grey water. Dealt with that (cheap coke) and smell went.
Minxy
32,488
66,008
E Yorks
Carthago Compactline
I'm not a fan of rubber pipes at all as they can easily have a very very small hole which can't be detected easily - could you remove all the pipes and take them out of the garage and put them somewhere else (not in the house!), leaving just the bottles in there and see if the smell disappears and/or is still apparent where you've put the pipes?
