4 Hole 36 ltr GAS IT Plus upright refillable Vapour tank. This refillable Tank is fitted with 4 separate valves and many safety features.
1) The outlet is fitted with a full excess flow valve meaning the tank will shut off automatically if the pigtail bursts ( unique to GAS IT Plus bottles )
2) Inside the tank there is a full liquid Phase separator© which stops any liquid from leaving the bottle
3) Separate Level float sender allows both on bottle and remote indication anywhere on the vehicle of the gas contents with a separately available GAS IT LED gauge and sender.
4) Full size large flow Pressure relief valve stops
This is a 36 ltr water capacity which means it holds 20% less than this amount due to automatic 80% float driven shut of filling valve in the tank, meaning you will never over fill the bottles even when only part of the gas has been used. They will always only ever fill up to 80%
Comes complete with a 9 LED gauge and sender, which picks up the level from the already fitted float magnet in the 4 hole refillable bottle, which the sender identifies and relays it to the GAS IT led gauge inside the vehicle.
1 x 1.5mtr Straight GAS IT Fast Fill Hose
1 x 0.45mtr 21.8LH to W20 pigtail
Size 300mm x 702mm (680mm without the shroud)
Bottle is 18 months old and is nearly full of gas.
£225
Pete
£225
Pete
