- Sep 12, 2022
- 18
- 5
- eurotrial cheyenne
Gas fire not working is the a separate tap like there is for the cooker?
If so where can I find it please.
Note: This feature currently requires accessing the site using the built-in Safari browser.
1992 eurotrail CheyenneGas fire not working is the a separate tap like there is for the cooker?
That is a big question, there is likely to be a seperate gas tap but where it is depends on the fire and the van. Do you have more information and a picture?Gas fire not working is the a separate tap like there is for the cooker?
On my 1995 m/h the three are Hob, Oven and Fridge.There’s 1tap in bottle locker. And think 3 by sink that does the cooker
No 1 does cooker , 1 does fridge , 1 does fireAnd think 3 by sink that does the cooker
Thank youNo 1 does cooker , 1 does fridge , 1 does fire
I’ll check tomorrow.No 1 does cooker , 1 does fridge , 1 does fire
Don’t know only bought Saturday.Has heater worked in past??? If so why suspect the valve, and who closed it??
Or are you wanting to find valve so you can isolate heater.!!
I would read the manual if it had one lolDare I ask, have you read the manual!
Just saying often find things in there.
The gas heater has its own separate tap close to the heater below a removable panel at the bottom of the wardrobe.
Obviously this is the 3-way
Need to find to see if open as fires not firing upDon’t know only bought Saturday.
People only went out in summer and said never used it.
Quite confident working on things.If the heater has not been used for a long time it will take a long time to get the gas through. If you are not confident working with has appliances I would advise gett a professional to have a look
Thanks I’ll check it later.It may be a blocked injector
