We had oily residue in the hoses on a caravan years ago, it took me ages to find as intermittently appliances wouldn't work, it was trapped in a loop, I blew the lines through with a compressor and all was fine after that.I just changed my cylinders around at the weekend as I was fitting the fill point in the skirt and found some oily residue coming out of a pigtail and wondered if I should get a filter?
I have found oily residue in the filter bowl and I am glad it didn’t reach the regulator. The residue is supposed to run back down the pipe and into the cylinder but if it is not doing this a filter might be a good idea.I just changed my cylinders around at the weekend as I was fitting the fill point in the skirt and found some oily residue coming out of a pigtail and wondered if I should get a filter?
After about 3 years I have not yet found the need to replace the filter cartridge, despite some residue accumulating in the filter bowl.Hi All,
How often, if at all, do you Guys change the gas filter?
Cheers, Ady
