Gas explosion in a Hymer in Oswestry, Shropshire (1 Viewer)
18,017
48,064
The price is £40k at the start of the story then suffers a degree of inflation I think. Glad no one hurt.
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Do you think they meant 40000. Can't imagine what you'd build into a motorhome to make it almost half a million pounds. And the insurance on it would be astronomical.
Lucky family weren't in it at the time.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Police say they are keen to speak to this man who was seen leaving the area
:D
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
'It highlights how dangerous gas canisters can be when involved in a fire - they can go bang.'
said Ian Leigh, Fire Service station manager and fire investigation officer for Shropshire Fire and Rescue Service.
Wish I was bright enough to be a fire investigation officer. :(:(
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
lpg bottles shouldnt go bang thety have pressure release valves on them . they should release a quantity of gas that flares up that all. only very small canisters dont have them .
oxy bottles do go bang .
DuxDeluxe
14,658
72,701
Planet Zog
A woosh bang van
If the rate of gas boil off exceeds the capacity of the safety valve then pressure will build and build until something gives. Result is a catastrophic explosion called a Bleve......
http://en.m.wikipedia.org/wiki/Boiling_liquid_expanding_vapor_explosion
You don't want to be anywhere nearby when that happens. There is some scary footage on YouTube. Hampshire fire service demonstrated to us on a gas firefighting course some years ago using a butane cigarette lighter refill
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
but with lpg it doesnt exceed the release valve . using a gas lighter refill is just to frighten you it doesnt have a release valve .
DuxDeluxe
14,658
72,701
Planet Zog
A woosh bang van
No, it was to demonstrate the effect not frighten us. We served on 40,000 m3 gas ships.........
Look at rail cars - there is a famous bit of footage where the cameraman was killed along with a lot of others due to a bleve. Please don't try and say that rail cars don't have safety valves. They do. I've seen and worked with enough of them.
Having said that, the Hymer explosion would not have been a bleve. Please read the science behind it. They can and do happen, which is why the fire service cordon off any cylinder fire or fire where cylinders are suspected to a great distance..... But hey ho, what do they know?
icantremember
8,331
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I've never seen an LPG cylinder of any sort with a safety valve? Where's it hidden?
On Calor cylinders and probably most other makes the "Safety" outlet is on the valve directly opposite where the tails are screwed in and is marked to keep hands off.
I believe it is a plastic material designed to melt before the cylinder explodes.
DuxDeluxe
14,658
72,701
Planet Zog
A woosh bang van
Yes, that is right......... Though it will not be enough in some circumstances. The below from Wikipedia
In a fire, the pressure in a gas cylinder rises in direct proportion to its temperature. If the internal pressure exceeds the mechanical limitations of the cylinder and there are no means to safely vent the pressurized gas to the atmosphere, the vessel will fail mechanically. If the vessel contents are ignitable, this event may result in a "fireball". If the cylinder's contents are liquid, but become a gas at ambient conditions, this is commonly referred to as a Boiling Liquid Expanding Vapour Explosion (BLEVE).
Medical gas cylinders in the UK and other countries have a seal of Wood's metal between the valve block and the cylinder body. This seal melts at a comparatively low temperature (70°C) and allows the contents of the cylinder to escape in a controlled fashion, lessening the risk of explosion.
I've watched them being tested at HSE. Put tank in a pit and set a fire all around it ( can't remember what the fire was ) then eventually Woooooooooooooooooooooooooooosh when it vents.
The words of the explosives guy "if anything is left it's a fire, if nothing left it's an explosion", you get this picture from all the middle east bombings.
DuxDeluxe
14,658
72,701
Planet Zog
A woosh bang van
Yes, even with a lighter fuel can it was spectacular - simply on a bit of concrete block in a tray of burning diesel. In the video below they heard the whooshing noise which was the venting but finally it all became too much for the cylinder. What happens is that the heat is conducted away by the liquid, but in the vapour space the metal heats right up causing stress in the cylinder. Finally the pressure gets to be too much and cylinder failure results - with a whole load what was was liquid suddenly turning to vapour due to the huge pressure drop. Ker-bang!!
upload_2014-8-10_9-46-16.jpeg► 1:46► 1:46
www.youtube.com/watch?v=Xf3WKTwHpIU
