Gas can trouble (1 Viewer)
Ninko
5
Hi,
My mother-in-law recently bought her first motorhome and I was helping her connect up this gas can, but even with a spanner I just can't do it tight enough to stop the gas from escaping.
And I was wondering, is there meant to be some kind of rubber washer between the pipe and the can, or am I just generally missing something?
Ninko
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Check your threads.... sounds if it is cross threaded..
PS... If it is propane it does not have a washer....
Butane Yes.. (I think)
7,231
20,083
Barnard Castle, UK
Concorde Concerto
You need to take it to someone who knows what they are doing, to check for safety, leaks etc, to tell you what you need and to connect everything up safely.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
N
Ninko
5
I assume it's propane, it's in a red can.
If there's no washer required, why can't I do it up tight enough to stop gas escaping, it's only a screw on pipe, surely you don't need an expect every time you need to connect up a gas can?
Ninko
3,738
3,849
Low profile
Is it one of these where the gas is escaping from?
get some soapy water on it so you can see exactly where it is escaping from.
N
Ninko
5
Thanks.
I think that's the same connector but it doesn't have that red circle bit on it, it's just a brown rubber hose.
Ninko
2,931
9,915
North Essex
Autotrail Delaware
>12 but <13
Are you saying the brass fitting doesn't have the red regulator? What's on the other end of the brown hose?
1) Yes a red regulator similar to that in thread above
2) No, brass connector to brown hose
3) Where does other end of brown hose go and what is it connected to?
Gas should go through red regulator to become low pressure or,
should go through fitting at high pressure to a wall mounted regulator to become low pressure
N
Ninko
5
It seems to fit on alright and screw up, it just doesn't seem to seal tight.
I'm pretty sure it's brown, it's like those little gas pipes you use to have in science at school that connected your bunsen burner.
Ninko
9,069
18,477
Salisbury
Hymer B678DL A class
since 2011
If I were you I’d take it to a calor dealer and ask them to check it out or you could end up in hospital(y)
5,407
21,549
Cumbria
since 2011
Some propane fittings do have a rubber seal or an o ring on them, especially the "hand tighten" ones, does the end look as if there is a groove for an o ring or does it have a step on it ? It normally should be just a shallow cone shape, Google images will show you, but as some have said, a nick, ding or bit of crap will allow it to leak.
TheBig1
17,612
43,146
a photo will help. not unknown for the thread on a gas cylinder to be faulty. have you got another cylinder to try?
Minxy
32,629
66,498
E Yorks
Carthago Compactline
Ninko
You're talking about the cheapest type of rubber hose by the sounds of it - how old is it? They need replacing every 3 years I believe (haven't had one for yonks so just going from memory!).
If its a bottle top regulator then you might be best getting a new one at the same time as replacing the pipe (neither are expensive) so you know you have a good set-up rather than use second-hand ones which you haven't got a clue of the age of.
9,069
18,477
Salisbury
since 2011
It’s quite obvious to me that @Ninko hasnt got a clue and it’s dangerous to try and help he needs a expert to look at it IMHO. Just saying(y)(y)
N
Ninko
5
I think it's like the picture Janine posted, but it's brown not black.
Ninko
4,917
29,490
Uk
C class
Since 2017
GO TO A GAS SUPPLIER OR MOHO/CARAVAN CENTRE TO GET IT LOOKED AT.
And,yes,I am shouting. Don’t mess with what you don’t understand if it is capable of killing you.
3,422
12,204
South Staffs
Pilote P740GJ
Since 2013
@Ninko try and take a photo of the connection and also what the pipe goes to, propane gas is not something you want to be messing with if you don’t know what you are doing.
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Ninko
It would seem likely (colour is not important). How do you know where the gas is escaping from? Have you tried using soapy water? There are several places that gas might escape from.
Some pigtails (the bit that screws into the cylinder) do have a rubber washer. There will be a groove where the insert should be, whereas standard fittings have no groove and are slightly domed.
They should not need to be tightened very hard. Better to get someone who knows what they’re doing to have a look. But, if it was my mother-in-law, …
funflair
19,325
30,144
Guisborough
MORELO palace
since 2012
Its not unknown for the bottle threads or sealing face to be damaged, I had a Propane bottle that had the brass tread knocked pretty hard and it went oval, bugger to get regulator screwed in and sealed, If we had not been in Spain it would have gone straight back.
Martin
11,953
16,567
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
DO AS @Podney SAYS - I'm SHOUTING TOO. If you need to ask these questions you should not be attempting the job. Depending on the position of the regulator, and I'd like to think you know what a regulator is, the hose could carry LPG at appliance pressure (minimal) or at over 100psi. NO GAS CONNECTION NEEDS TO BE AS TIGHT AS YOU ARE DESCRIBING.
scbunurse
84
52
Inverness
Test driving tomorrow !!!
Newbie
Even tho' I'm new here I have camped for years and have seen a caravan destroyed in minutes by a faulty gas appliance. Thankfully no one was seriously hurt but you never forget something like that. Please, please listen to these good people and get it checked by an expert.
