Gas bottle sizes (1 Viewer)
Paul J
220
40
I guess this has been covered about a million times, so forgive me for asking, prompted by a recent Facebook post about 13KG Calor Propane bottles. My local supplier only has the 6KG Propanes which I'm using now and used in my previous motorhome some years ago, we only had 4 nights away, and already are empty on one bottle, I'm keen to wonder if I can get a bigger bottle and better value. I think I pay around £24 for a refill.... but at this rate it could be a pain to keep swapping bottles, and it's not even winter yet !
I have a Roller Team T-Line 590, which has a storage compartment compatible with 2 of the larger bottles, but I'm fairly sure they don't recommend carrying that weight, so it's unclear to me what I ca/should fit.
For my current bottles, I blagged some empties via my local facebook group, and swapped them into the filled bottles, can anyone let me know how this works with other suppliers like Morrisons ? if I can get hold of Calor 13KG Propanes, I can just go there with my empty ?
any help, much appreciated
thanks
tonka
10,670
21,019
Cannock, Staffs
A class Burstner 800
Since 2000
Calor bottles can be swopped at any place that sells Calor gas... (y)
Your not tied down to 1 outlet...
Also, depending on your location look at other suppliers like Flogas.
Think I used to pay £24 but that was for a 13kg exchange..
Buying in 6kg's is false economy if you can get 13kg in the locker...
Paul J
Paul J
220
40
Just had a quick look, and we have a local Calor place, I think they would be a better option, I didn't even know you could get 13KG propane, only because (as far as I'm aware) our local place doesn't do them.
will check it out, thanks for the advice
May 7, 2011
4,778
139,538
Cornwall Gorran Haven
T Line 785
motorhoming since 1979
Hi, in my T-Line 785 , it holds up to 15kg in the locker (thats what the handbook states )
but I use a 11 kg bottle & a 6 kg propane ,
the locker floor is plastic , so I personally wouldn't put 2 x 11 or 13 kg
Paul J
Paul J
220
40
maybe perhaps I'll try and get a 13kg Calor and keep one of the 6kg's which I already have
42,963
47,029
You could, and I would, cut a piece of 1/2" ply to the size of the locker floor and drill holes corresponding to the gas drop vents and put that in..... You could then stand concrete blocks in there if you wanted to. Just cos the converters have no common sense doesn't mean you can't work around their mistakes. .
Paul J
Paul J
220
40
great advice re strengthening the floor, thanks for that
Northernraider
25,864
152,427
On the sofa ....
Hymer 654
On and off since 95
You don't need to get empty 13kg bottles
You can exchange the 6kg empties for 13kg full bottles but obviously you'll have to pay the additional fee.
I've done this several times in the past before I got refillable systems
As long as it's their own bottles
Theonlysue
6,098
7,368
Essex
As Executive 50th an
Not long enough!
Ive used 36 litres in 3 days at minus 15!
Theonlysue
6,098
7,368
Essex
Not long enough!
Alde heating. But it was warm in the mh!
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Cant believe the amount of gas some people are using i can do 6kg in 4 days and van is very warm - so i'm wondering if the vans that use more gas have a large garage at back of van with large access doors each side or some vans are better insulated than others
RowleyBirkinQC
2,237
205,844
Dazed & Confused
We used to run on a couple of 6kg Calor bottles but now have a single 14kg Alugas refillable bottle. The bottle itself is very low weight, other sizes available, take a look at Autogas 2000 website.
Northernraider
25,864
152,427
On the sofa ....
Hymer 654
On and off since 95
I found my alde to be very heavy on gas and there were still cold bits in the cab and in the rear bedroom above garage.
I've found the truma to really heat up this hymer to the point you've to turn it down.
Not sure about gas useage yet so will see how that goes compared to the Frankia
But I got maybe 3 days out an 11kg bottle with that.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
My heating has a truma gas fire as you say gets very hot and needs turning down maybe the aldi system is a lot heavier on gas usage
Jul 5, 2013
11,512
13,336
Since 2013
We are I suspect heavy users of gas. My wife has poor circulation and does not like the cold, so we have the heating on a lot. We are not finding gas usage much different in our 7.5m Alde heated A class Hymer as we did with our previous 7.2m Truma heated C class Adria. Both had similar layouts with longitudinal single beds over a large garage.
What we do find is the Hymer feels much cosier and is more evenly warmed. Just a personal impression though, and it is especially so in the cab area, which always felt cooler in the Adria. Our Alde heating has the facility to switch off the heating in the rear bedroom area with an isolating valve. If you find that the your moho is cooler in the bedroom with Alde heating it may be because your system has that valve and it has been left closed.
WynandJean
6,666
3,306
West Midlands
Bailey Autograph 682
Since 2010
I think this must be why so many responses to questions about gas usage say something like, "we bought a bottle of gas xxxxxxx ago and still have half of it left after crossing Siberia". We have been surprised at how much gas the Alde system uses since changing our van from one with Truma heating. All I can say is thank goodness it's refillable! I saw a post saying that Alde would expect a 6lt bottle to last not much longer than a weekend, and I have to say that's not far off what we have been getting - perhaps 4 days or so.
Wyn
Duck Truck
1,203
1,224
UP North
Hobby 725
since 2012
Gas usage depends on:
The outside temperature
The size of the van
The design of the van
The insulation of the van
The heating system of the van
How much hot water you use
The people using the van, one man/womans hot is anothers cold.
two
Aug 4, 2011
4,805
4,414
West Midlands
A-Class Fiat
The size of the van
and a few more conditions, but none should be whether it's Truma or Alde. They should both produce the same amount of heat from the same amount of gas, the only difference being the way they distribute it.
When I started caravanning, I had two 'dumpy' cylinders on the A-frame. We must've been much 'harder' in those days. There was no heating and not much insulation. Gas was used for cooking and lighting (mantles) and I don't recall the gas consumption being a problem. (Perhaps that's what contributed to my poor memory?)
vwalan
Sep 23, 2008
8,834
5,797
roche cornwall
lynton5th wheel
since a child
what you dont use gas lights anymore. why not .
you will be telling us next you can get leccy lights .
gas lights give light ,heat and a nice cozy feeling in the dark evenings . and help keep mozzies away.
use tie on mantles these days always available on ebay.
Jul 5, 2013
11,512
13,336
Since 2013
And ensures you talk to one another, because you can't read by them, or at least not at my age!
Oct 11, 2016
1,286
2,191
Bognor Regis
Bailey Adamo 69-4
6 years
Not if you’ve got the heating going(y)
I was a bit previous in making my original comment. We have only used EHU due to the need of being able to use a hair dryer ( there will be some of you who understand where I am coming from!! ) Therefore our use of gas is low.
