Gas Bottle indicator valve
Mijack
Autotrail Tracker FB
Newbie
Hi All.... First post here, so forgive the inexperience! :hi:
I purchased one of these propane gas bottle level indicators that screw onto the pipe/bottle. (see pic)
However, when it was on the bottle, it didn't register... even though it's a full bottle. Neither did it feed any gas through to the cooker in the MH.
It's not blocked, as I can blow air through it when it's off the bottle. Am I doing something wrong? Are these not meant to be used on a MH?
For some of these you have to reset them after connecting to cylinder and turning on.
Some, similar to your pic, have "push to reset" printed on the dial
Broken Link Removed
If they are supposed to work by sensing the pressure I can't see how it's going to work until right at the very end of the bottle as the pressure of vapour above the liquid gas will be fairly constant until there's no liguid gas left at least that's the way it would seem to me.
For it to work it would screw directly into the bottle then attach the regulator? Maybe why it needs resetting as per Sandral's post
##Update## As per Sandra's post, I found that I had to press the indicator dial (never knew!) as this re-sets it and the dial works. BUT.... it interferes with the 'purge' button on the gas pipe (which Autotrail/Truma fitted).... so when I press the purge button, the needle on the gauge goes to zero and no gas goes through to the cooker. Well... only a residual amount that the purge button pushes through... after that, no gas.
So, I guess this was an idea that will not work on this set up.
Maybe mine were not faulty then. But instructions didn't mention pressing the dial.
I did have a Gaslow one on our boat and that worked very well.
Try a Truma gas level pen hoping it works well as one arriving shortly.
Pressure is a very poor indicator of contents. The pressure should remain constant until the bottle is very nearly empty. I had one on a boat and it was no help at all.
Has anyone tried a Truma Level Check or Truma Level Control on an Alugas refillable? Truma say the existing gauge mechanism on refillables interferes with readings.
A mopeka user here. A well trusted ultrasonic / bluetooth method. Probably the cheapest ultrasonic device, i bought mine amazon.com no problem. Used with gaslow and calor bottles Many other users on fun.
Thanks for all your input, people!
I've decided on the simple option of having 2 bottles... switching the pipe over as and when the first runs out. We mainly stay on camp sites for overnighting, so most will have a gas bottle replacement service.
:thanks3:
