Does anyone know when in use can it powered via a USB port into the micro power and data port on the side so avoiding using the mount which the power cable goes into.Without the mount I can fit it into the dash tablet holder
So if I plug a USB adapter into the cigarette socket would that do the same job.If you have the 890 LMT-D I believe that live traffic updates are only available via the smartapp so you should be able to use the supplied power lead directly to the device instead of to the mount. If you wish to use just a USB lead then you will need to make sure that is is providing sufficient power. My 770 won't run & charge in the USB port in my car. It will charge if it is turned off but the USB port in the dash doesn't provide sufficient power when it is running, so after about an hour it shuts down due to low battery. I fitted a 12V to USB charger, 3A output, under the dash in the MoHo and that works like a charm.
Thank you one and all for your help.The usb connections for the mount and device are different and the traffic information is obtained via an app on a smart phone so I think I'll go down the upgrade usb in the cigarette lighter and see what happens.If garmin support gets back to me with any other ideas I'll update on here for members info.
Hi, we have a Camper 890 and want to do the same as you. We have found that our standard USB output is enough to keep the device charged while navigating, even without using the cigarette lighter output, but there seems to be a software issue. The device’s software thinks that because the device is not plugged into the mount’s USB port, it can’t be getting enough power, and so it shuts down after a set period of time. On the settings, we’ve managed to change this to 30 minutes, but can’t switch it off entirely.Thank you one and all for your help.The usb connections for the mount and device are different and the traffic information is obtained via an app on a smart phone so I think I'll go down the upgrade usb in the cigarette lighter and see what happens.If garmin support gets back to me with any other ideas I'll update on here for members info.
I find 'Traffic Information' more of a hindrance than help.For a £400 unit not to have traffic information without being tethered to a mobile phone is a bit naff to say the least.
When the 'must have' becomes the 'don't use' ...I find 'Traffic Information' more of a hindrance than help.
Frequently out of date, even Google Maps shows slow moving traffic where I live, when there is no traffic and there hasn't been for days.
As a result I disable any such 'feature'.
The you haven't used Tom-tom's traffic information which is normally spot on with remarkably accurate journey times. Probably the best feature and why the built in SIMs are so important as TomTom uses anonymous measurements from GPS navigation devices, smartphones, commercial fleets and sensor data for its traffic information.I find 'Traffic Information' more of a hindrance than help.
YupSo the "cigarette lighter " plug for the 890 is not USB, it's 8-30V output. This feeds the mag mount, and is therefore pretty straight forward to hardwire in.
